MHB How to Solve a Terminal Arm Word Problem and Using Latex
  • Thread starter Thread starter mathdrama
    Arm Word problem
To solve the terminal arm word problem, the correct approach involves calculating the principal angle using the formula $$\theta=\pi-\left(\tan^{-1}\left(-\frac{5}{2}\right)+\pi\right)=\tan^{-1}\left(\frac{5}{2}\right)$$. The primary trigonometric functions related to the angle subtended by the arm and the positive x-axis can be expressed as $$\beta=\pi-\theta$$, with the relationships $$\sin(\beta)=\sin(\theta)$$, $$\cos(\beta)=-\cos(\theta)$$, and $$\tan(\beta)=-\tan(\theta)$$. For those unfamiliar with LaTeX, a comprehensive tutorial is available to help users get started. Understanding these concepts will facilitate solving similar problems effectively.
mathdrama
Would this be an okay way to go about solving the problem? Also, how do I use Latex?
Mathematics news on Phys.org
You have sketched the arm in the correct quadrant. As for the principal angle, you are correct, however I would write:
It appears you are to find the values of the primary trigonometric functions of the angle subtended by the arm and the positive $x$-axis. So, you want to use the angle:
And recall:
As far as using $\LaTeX$, check out our excellent tutorial on getting started:
http://mathhelpboards.com/latex-tips-tutorials-56/mhb-latex-guide-pdf-1142.html
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
