Testing My Superconductor
23 replies · 4K views
auto_v
TL;DR
Testing superconductor
Hi, I would like someone to test the superconductor I have come up with or let me know how ( I don't have a lab ), what I can say that the resistance is almost zero with my Fluke.Regards
We can probably recommend some test labs in your area. What geographical area are you in, and what temperature do you need them to test it at?
Multimeters are good for routine electrical and electronic testing, but they struggle when measuring extremely low voltages, currents, and resistances.
A reading of 0 Ω indicates that it is less than the multimeter's resolution value of 0.1 Ω.
Reply
You need 4W measurement to get close to that. For common multimeters and common measurements a measured zero resistance is rather about an ill-adjusted zero point...
You can try the 'quantum levitation' experiment. Not really a measurement, but for 'testing' it's good enough here, I think.
Reply
Fluke 115 true rms is definitely not a common multimeter..., but its obvious that every superconductor will always be close to zero resistance, but not zero -I'm referring to a room temperature so we can skip this and proceed to testing.. I'm in Lithuania , so any test labs close by would be nice, temperature is obviously a room one..My superconductor is Type I, so levitation experiment would not suffice..
It is in California. Marketed mainly to field technicians. It's a good instrument for what it's designed to do, but it won't ever win the DMM Olympics.
Sorry to be the bearer of bad news, but I don't think you can do this sort of work without access to a really good lab. You also need a really good background in lab work, experiment design and such.
Reply
Sorry, but it is.
For those small things, we don't even bother to calibrate most of them at the company. And even our 6.5 digit benchtop suff can fall short, yet we are not even close to those ranges...
I agree with @DaveE here. You need a good lab and a mentor for this.
Check around some local universities. Maybe there will be some students up for an off-course endeavour.
Reply
Zero. They are zero, that's sort of the definition. That's the "super" part.
Reply
  • Haha
It is not capable of making 4-wire resistance measurements, which is what you need when measuring near-zero resistance. Are you familiar with 4-wire resistance measurements?
Also, the Wikipedia article describes how resistance measurements are made with superconductors. Have you read through that article yet? What is your background in superconductors so far?
https://en.wikipedia.org/wiki/Superconductivity
Since there are no room temperature superconductors yet, it seems likely that you will want to measure the sample's resistance versus temperature to find the critical temperature...
Reply
auto_v said:
TL;DR Summary: Testing superconductor
OK, I’ll say it. What is your superconductor material for kicks and giggles?
http://www.superconductors.org/Type1.htm
Please watch the profanity. Oh, wait... :wink:
Reply
  • Love
Zero resistance is not the criterion for superconductivity. It has to expel magnetic fields.
I thought it was defined as BOTH expelling magnetic fields AND having zero resistance.
Reply
Hmm, is there anything that expels magnetic fields that isn't superconductive? I dunno but had the idea that there wasn't.
Doesn't really matter. What matters is that the definition of superconductivity is that it have zero resistance. I think the "expels magnetic fields" is just an addition, but in any case, it's BOTH.
Reply
The complete displacement of the magnetic field from the volume of the superconductor (the Meissner effect) can be used to study your product. This experience is as follows. The sample is cooled with liquid nitrogen and, when it enters a state of superconductivity, a permanent magnet is placed over it. If the sample is superconducting, then the magnet will repel it and hang in the air. Of course, such an experiment should be carried out in a laboratory environment in compliance with safety measures.
The superconductor is a mixture of organic compounds and that is all i can say so far as you understand..Anyway I checked a voltage across superconductor and it is the same as resistance close to 0, I think I will need a lab to confirm the rest, if any of you can suggest any lab or person capable to do so in close proximity so I can send the sample and verify that it would be great.
I don't think we have many PF members from Lithuania, but I just did a Google search on test labs with low temperature capability and got lots of hits for labs near me. Maybe try the same search to find labs near you.
Reply
Apologies…My understanding is a Fluke “0”
:cool:
From the link in post #10, around -267°C.
Reply
UK is fine, if I am sending sample then it does not really matter.
Regards
Then extend your search for labs that have cryogenic test capability.
