The affects of Lenz's Law on Wind Turbines
Wind turbines continue to turn because the wind provides a constant source of energy that overcomes the counter electromotive force induced by the generator. While Lenz's law states that the induced current opposes the magnetic field, the ongoing wind supply ensures that the turbines reach an equilibrium speed rather than stopping completely. In an ideal scenario with consistent wind and electrical demand, turbines would maintain a steady rotation. The interaction between wind speed and electrical load is crucial for the turbine's operation. Therefore, as long as there is sufficient wind, turbines will not cease to function.
babayevdavid
Hi,
If an electrical generator induces a current that opposes the shifting magnetic field that creates it then why don't the wind turbines on wind farms just stop turning after a while? Is it because they are not directly connected or drawn on by electrical devices?
Thank you all in advance!
babayevdavid said:
Hi,
Because of the wind...
Sure, but at some point wouldn't the wind not be enough to counteract the effects of the counter electromotive force?
At some point you will reach equilibrium and the wind will counteract the effect of Lenz's law exactly and the turbine will simply spin at that speed forever (in an ideal world with constant current and wind supplies) .
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
