The Changing of Objects with Temperature-Thermodynamics
  • Thread starter Thread starter Weezergames
Weezergames
Im doing a project on The Changing of Objects dealing with Temperature can anyone give me a couple of good subtopics that i can use?
Melting/Freezing
Condensing
Sublimation
Oxidation
Plastic flow
Associated colour changes
Crystal formation
Effect on magnetism
There that should keep you going
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
