What Determines the Current in an AC Circuit with a Light Bulb?
  • Thread starter Thread starter Fazza3_uae
    Circuit Current
The discussion centers on determining the current in an AC circuit with a light bulb when a voltage is first applied. The maximum voltage is given as 763 V at a frequency of 22 Hz, and the light bulb has a power rating of 17 W. For part a, the correct answer regarding the current when the voltage is first applied is 0, as this corresponds to time zero in the AC cycle. In part b, the user attempted to calculate the current at t = T/4 but incorrectly used average power instead of instantaneous power, leading to an incorrect answer. The key takeaway is that the average power should not be confused with instantaneous values in AC circuits.
Fazza3_uae
The current in the circuit ...??
An AC voltage of the form V = Vmax sin 2*pi*f*t , with frequency 22 Hz and maximum voltage 763 V, is applied across a 17 W light bulb. When the voltage is first applied.
a) what is the current through the circuit?
Three Choices :
1. the maximum current
2. 0
3. the rms current
What is the correct answer and why ... ??
b) When t = T/4 , where T is the period of the applied voltage, what is the current in the circuit?
P = I * V
I max = \sqrt{}2 * I rms
T = 1/f
In part a) i think that when the voltage is first applied means that time is ZERO so it could be ZERO the options # 2
In part b) I substituted t = 0.25T or 0.25/f in this formual
I found V then I used P = I * V and solved for I but i got wrong answer.
17 W is the average power over a full cycle. It's equal to I_{rms} V_{rms}. You used this value as if it was the instantaneous power at t=0.25T
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
