The different between the work (PV ) in ΔU and the work (PV ) ΔH
  • Thread starter Thread starter izen
    Work
The discussion focuses on the differences between the work terms in the equations for internal energy (ΔU) and enthalpy (ΔH). It clarifies that ΔU is defined as the sum of heat (q) and work (w), while ΔH incorporates ΔU and the change in the product of pressure and volume (Δ(PV)). The conversation highlights that work is path-dependent, and for constant pressure processes, ΔH simplifies to q. Additionally, it addresses how to handle pressure in non-ideal gas scenarios and emphasizes that U and H are state functions, independent of the path taken. Overall, understanding these distinctions is crucial for thermodynamic calculations.
izen
By definition
ΔU = q+PV
ΔH = ΔU+PV
Well, what are the different between the work (PV ) in ΔU and the work (PV ) ΔH then ?
thank you
Both equations are incorrect.
ΔU=q+w
ΔH=ΔU+Δ(PV)
So, now, what is your question?
w= -P ΔV
in case of constant Pressure, ΔH= (q -PΔV) +PΔV >> ΔH= q
So w in ΔU will be the same when constant pressure with Δ(PV) in ΔH ?
if the pressure is not constant What is P in ΔU ? is it P external? and what is P in ΔH ? P in ΔH is Pressure of system? in case of ideal gas, Δ(PV) = nRT so where is P ?
and if not ideal gas how can we calculate Δ(PV) in ΔH?
Thank you
Dear izen,
These are all excellent questions, but I don't have time to respond right now. We are expecting some out-of-town relatives, and I'm pretty tied up for the rest of the day. I will get back with you as soon as possible to answer all your questions.
Chet
Hi Chet,
I will be waiting for you here. Enjoy your evening. :)
Izen
izen said:
w= -P ΔV
Thank you
You need to think of U and H as properties of a system characteristic of each state of equilibrium. ΔU and ΔH are the changes in U and H from one equilibrium state (say, state 1) to another equilibrium state (say, state 2). Even though there may be many paths that will take the system between the two equilibrium states, the changes in U and H are independent of the path.
On the other hand, the parameters q and w are quantities that are totally dependent on the path between the two equilibrium states. Only their difference is independent of the path. q and w are sometimes called energy in transit.
For expansion or compression, the work w is always determined by w = -\int{P_extdV}, not by w= -P ΔV. If the process is reversible, the pressure P within the system is virtually homogeneous, and, in addition, P = Pext (actually P differs from Pext by an infinitecimal amount). If the process is irreversible, the pressure within the system is not homogeneous, and so there is no one single value of pressure that characterizes the pressure within the system.
For the change in enthalpy, we have
\Delta H = q -\int{P_{ext}dV}+\Delta (PV)
where the pressure P and the volume V in the Δ(PV) correspond to the system values in the initial and final equilibrium states. If a process is carried out at constant external pressure, the change in enthalpy is given by:
\Delta H = q -P_{ext}(V_2-V_1)+(P_2V_2-P_1V_1)
In such a process, for the final state to be an equilibrium state, one must have that
P2=Pext. Under such circumstances:
\Delta H = q -(P_2-P_1)V_1
If the final pressure of the system is equal to the initial pressure (constant pressure process),
\Delta H = q
Examples of when this applies are (a) if you have an ideal gas, and you add heat to the chamber while the piston is moved in such a way as to hold the pressure constant and (b) a combination of saturated vapor and saturated liquid in the chamber, and you add heat while the piston is moved in such a way as to keep the pressure constant.
In the case of an ideal gas, there is no effect of pressure on either U or H. Both parameters are functions only of temperature. For a real gas, if you wish to calculate the effect of pressure on U and H, the formulation is more complicated. For infinitecimal changes between equilibrium states, the changes in U and H are described by the differential equations:
dU = TdS - PdV
dH = TdS+VdP
These equations apply only to differential changes between equilibrium states. The effect of pressure P on U and H are derived starting with these equations, and, by applying the so-called Maxwell Relationships.
Hi Chet thanks for the answer :)
