The Eigenfunction of a 2-electron system
The discussion centers on demonstrating that the two-electron wave function $$\psi(r_1,r_2)=\psi(r_1)\psi(r_2)=\frac{1}{\sqrt{\pi}}\left( \frac{Z}{a_0}\right)^{3/2}e^{-\frac{Z}{a_0}r_1}\frac{1}{\sqrt{\pi}}\left( \frac{Z}{a_0}\right)^{3/2}e^{-\frac{Z}{a_0}r_2}$$ is an eigenfunction of the Hamiltonian for a non-interacting system. The key issue raised is the calculation of energy, specifically ensuring that the Hamiltonian is correctly applied to the two-electron wave function. The participant identified that the term ##-\hbar^2 / 2m## does not factor out correctly, leading to confusion in deriving the expected energy value. A simple suggestion from another user ultimately resolved the participant's issue.
  • Understanding of quantum mechanics, specifically eigenfunctions and Hamiltonians.
  • Familiarity with wave functions in multi-electron systems.
  • Knowledge of the Born radius and its significance in quantum systems.
  • Proficiency in mathematical operations involving partial derivatives and Laplacians.
  • Study the derivation of the Hamiltonian for multi-electron systems in quantum mechanics.
  • Learn about the implications of the Born radius in quantum mechanics.
  • Explore the concept of eigenvalues and eigenfunctions in the context of quantum systems.
  • Investigate common pitfalls in calculating energy for two-electron systems.
Students and researchers in quantum mechanics, particularly those focusing on multi-electron systems and eigenfunction analysis. This discussion is beneficial for anyone looking to deepen their understanding of Hamiltonians and wave functions in quantum theory.
Settho
Show that the wave function is an eigenfunction of the hamiltonian.
Hamiltonian, wave function, energy and Born radius
Hello!
I am stuck at the following question:
Show that the wave function is an eigenfunction of the Hamiltonian if the two electrons do not interact, where the Hamiltonian is given as;
the wave function and given as;
and the energy and Born radius are given as:
and I used this for ∇ squared:
I am stuck at the end of the calculation. I know Z = 2, but somehow I don't end up with the energy, which you need to show that it is indeed an eigenfunction. This is what I get and where I am stuck at:
and even when I substitute a0 in this formula, I don't get the energy value. I honestly don't know where it did go wrong.
If someone is able to help, that would be great.
You need to substitute the two-electron wavefunction$$\psi(r_1,r_2)=\psi(r_1)\psi(r_2)=\frac{1}{\sqrt{\pi}}\left( \frac{Z}{a_0}\right)^{3/2}e^{-\frac{Z}{a_0}r_1}\frac{1}{\sqrt{\pi}}\left( \frac{Z}{a_0}\right)^{3/2}e^{-\frac{Z}{a_0}r_2}$$in your Hamiltonian. The energy is a constant and should have no ##r## dependence.
But isn't it just the idea to split the Hamiltonian in electron 1 and electron 2 instead of the two-electron wave function?
The ##-\hbar^2 / 2m## term doesn't factor out of all terms.
Your simple suggestion made me solve the problem. Thank you so much!
