The Fill Factor of the Silicon Photocell
  • Thread starter Thread starter ZaZu
    Silicon
The discussion revolves around calculating the fill factor of a silicon photocell, with a participant reporting a value of 1.6x10^-2 based on their calculations using Pmax and Po. They express urgency in confirming this value for their lab report submission. However, another contributor points out that the fill factor is defined as the ratio of the photodetector area to the total area of the circuitry, indicating that necessary area information is missing for a proper calculation. The participant references their lab manual instructions, which emphasize finding the maximum power point on the i-V characteristic. Clarification on the fill factor's definition and the need for specific area data is essential for accurate results.
ZaZu
I have to find the value of the Fill Factor of the silicon photocell.
I graph for current, voltage and power.
I got this as a value 1.6x10-2
Is this the correct answer ?
I just need the real value so I can compare it with my results ..
Pmax/Po
Pmax/Po = (9.5x〖10〗^3µW)/(5.7x〖10〗^5µW) = 1.6x10-2
I have to submit the lab report tomorrow .. Please help me =[
The fill factor is "ratio of photodetector area to total area of the circuitry".
You have given no information on these areas, so no answer can be computed.
Umm ... I followed what the lab manual told me ...
" Calculate the fill factor, defined as the ratio Pmax/Po. Find the position of the point where the power is maximum on the i-V characteristic and draw a line to it from the origin. This is called a load line. "
:S
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
