The first law of thermodynamics for open systems
The discussion focuses on applying the first law of thermodynamics to open systems, specifically in calculating the average temperature in a combustion process involving propane (C3H8) and air. Participants emphasized the importance of determining the mass flow rates of both propane and air, with specific values provided: the mass flow rate of propane is 1.25 x 10^-3 kg/s, and the calculated mass flow rate of air is 1.19 kg/s. Key equations discussed include the heat release rate (Qdot) and the relationship between mass flow rates and temperature changes, specifically T2 = T1 + Qdot / (P * Vdot * Cp).
  • Understanding of the first law of thermodynamics in open systems
  • Familiarity with combustion chemistry, specifically propane combustion
  • Knowledge of fluid dynamics, including mass flow rate calculations
  • Proficiency in thermodynamic equations, including heat transfer and specific heat capacity
  • Learn how to calculate heat release rates in combustion processes
  • Study the principles of adiabatic flame temperature calculations
  • Explore the effects of excess air on combustion efficiency
  • Investigate the relationship between mass flow rates and temperature changes in thermodynamic systems
Students and professionals in chemical engineering, mechanical engineering, and thermodynamics, particularly those involved in combustion analysis and energy systems optimization.
Gaby
A fire is created in a room. The height of the door is 1.83 m and its
width is 0.74 m. The neutral plane is established at the height
1.0 m. The fire is sustained by propane (C3H8) with a mass flow
rate of 1.25 X10-3 kg/s and the oxidiser is air (79% vol. nitrogen
N2, 21% vol. oxygen O2). The air flows through the door opening
with an average velocity of Vin=0.7 m/s and a temperature of
Tin=298K.
(iv) Determine the average temperature and velocity of
outflowing gases.
Apply the principle of energy conservation for a steady-state open
system. Neglect the difference in kinetic and potential energy of
inflowing and outflowing gases as compared to the rate of energy
transfer to the gases (i.e. due to the heat release rate by the fire).
Assume that
− the combustion is perfect,
− the entire heat of reaction is spent on heating of gases in the
room;
− the average specific heat of outflowing gases is
cp=1050 J/kg/K and the average molecular mass of the
outflowing gases is equal to that of the ambient air
Min=Mout=29 kg/kmol.
(Please see enclosed pdf doc, sorry equation wont copy correctly into text box.)
Please see enclosed my calculations for parts 1-3.
I am stuck on the final part of of a 4 part question, any help or guidance would be very much appreciated, thanks.
You do the final part the same way you determined the adiabatic flame temperature, except that, for this system, the air flow is not stoichiometric: Q = 0 and ##\Delta h=0##
Hi thanks for this. To find the average temperature do I need to find the heat release rate? ( hc x mass flow rate) & mass flow rate = volumetric flow rate x density; I ve been stumped on how to approach this question; I would be very grateful on any guidance on how to approach it, thanks.
In the mixture for this problem, there is probably excess air. The heat of reaction per unit mass of propane is known (what is it) and you know the mass flow rate and specific heat of the exit stream.
Thanks!
Hi Chestermiller, Are you able to expand this a little as I am still confused. Any help is much appreciated!
Sure. For this problem, what is the mass flow rate of the C3H8 and of the air?
Thanks very much. Mdot for propane = 1.25 x 10 -3. I don't know the mass flow rate for the air. Sorry!
You can calculate the mass flow rate of the air from the information provided in the problem statement.
Is it m=pVA
= 1.19 kg/s
BigRed42 said:
Is it m=pVA
= 1.19 kg/s
What values did you use in this equation? I get a different result.
A= 1.35m2
V=0.7m/s
p=1.184
Thanks!
BigRed42 said:
A= 1.35m2
V=0.7m/s
p=1.184
Thanks!
Shouldn’t the area only be 0.74 because the air is only coming in in the bottom part of the window?
Ahhh That would make sense. Thanks! So do I just use the mas flow rate and the other known values in the equation
T2= T1 + Qdot/ P.(Vdot).Cp?
You need to use the total mass flow rate of both propane and air. What do P and Vdot mean?
Hi Chester, V(dot above the letter) Volume flow rate. Q(dot) Heat release rate. P is the pressure at 1atm
Thanks for your help.
In my judgment, that relationship is not correct. The correct relationship is
$$\dot{m}C_p\Delta T=\dot{n}(-\Delta H)$$where ##\dot{m}## is the total mass flow rate of propane and air entering the system (or reaction products leaving the system), ##\dot{n}## is the molar flow rate of propane entering, and ##-\Delta H## is the molar heat of combustion of propane.
  • · Replies 24 ·
  • · Replies 46 ·
  • · Replies 37 ·
