The greatest and lower value of the function in this segment.
  • Thread starter Thread starter Penultimate
    Function Value
The discussion revolves around finding the greatest and lowest values of the function \( y = x + \sqrt{x} \) over the interval [0, 4]. Participants are exploring the relationship between the function's critical points and its endpoints to determine these extrema.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to derive the function and evaluate it at the endpoints of the interval, as well as at critical points where the derivative equals zero. There is some uncertainty about the clarity of the steps involved in this process.
Some guidance has been provided regarding evaluating the function at the endpoints and finding critical points. Participants are actively engaging with the concepts but have not reached a consensus on the specific steps or clarity of the explanation.
There is an emphasis on understanding the conditions under which maximum and minimum values occur for continuous functions on a closed interval, as well as the need for clarity in communication of the mathematical reasoning involved.
Penultimate
What is the greatest and lower value of the function[tex]y=x+\sqrt{x}[/tex]
in the segment [0,4]?
I knowit has to do with deriving it , but i don't know how to explain it.
Any help :D
The maximum and minimum of a continuous function f on [a,b] can only be in at a, b or a number c which satisfies f'(c)=0.
Thanks that's gives a clue.
So i replace a and b in the function , then equals it to 0 and compare a ,b and c. Isnt it so?
yes that's correct.
This is pretty vague, so you might understand what you mean, but you're not stating it clearly. What you need to do is to evaluate f(0) and f(4). Then you need to find f'(x) and set it to zero. If there is a number c for which f'(c) = 0, then evaluate f(c). Of the three numbers f(0), f(4), and f(c), one of them will be the largest function value on the interval [0, 4] and one will be the smallest.
