The Limit of a Root of a Function is the Root of that Limit (delta-epsilon)
5hassay
Prove:
If \lim_{x \rightarrow a} f \left( x \right) = l, then, if \sqrt[n]{f \left( x \right)} exists, \lim_{x \rightarrow a} \sqrt[n]{f \left( x \right)} = \sqrt[n]{l}.
Nothing really...
Okay, so here goes my attempt...
Proof. We can assume that
\forall \varepsilon > 0, \exists \delta_1 > 0 : \forall x, 0 < \left| x - a \right| < \delta_1 \Longrightarrow \left| f \left( x \right) - l \right| < \varepsilon,​
whereas, we want to show
\forall \varepsilon > 0, \exists \delta_2 > 0 : \forall x, 0 < \left| x - a \right| < \delta_2 \Longrightarrow \left| \sqrt[n]{f \left( x \right)} - \sqrt[n]{l} \right| < \varepsilon.​
But, \varepsilon > \left| f \left( x \right) - l \right| \geq \left| \sqrt[n]{f \left( x \right)} - \sqrt[n]{l} \right|. Therefore, we conclude that given \varepsilon > 0, if, for all x, 0 < \left| x - a \right| < \delta for some such \delta, then we have both \left| f \left( x \right) - l \right| < \varepsilon and \left| \sqrt[n]{f \left( x \right)} - \sqrt[n]{l} \right| < \varepsilon.
QED
So, I guess the first remark would be if my method was even right, where the second would be if my inequality is true (I can't think of a counterexample).
Anyway, much appreciation for any help.
For n=2, f(x) = 1/2 and l = 0 is a counterexample.
Oh, drat. Then, I am at a loss on what to do.
Hmm... I'm likely misunderstanding, but if f \left( x \right) = 1/2, then wouldn't l = \lim_{x \rightarrow a} 1/2 = 1/2 for any a? That is, I don't understand how the limit l could be 0.
Much appreciation
Sorry, what I wrote wasn't very clear. I meant if f=1/2 for some value of x near a, then the implication your proof relied on doesn't hold. I didn't mean that f was a constant function.
|\sqrt{f(x)} - \sqrt{L}| = \frac{f(x) - L}{|\sqrt{f(x)} + \sqrt{L}|}.
The denominator of the right side of the equation can never be zero unless f = 0 in some neighborhood of x= a and L = 0 (in which case the proposition you're trying to prove is trivial). Why?
Once you answer that, let x approach a and see what the limit of the right side of the equation is.
Alright... I've been trying to understand these hints, but I unfortunately don't seem to get anywhere. However, I realized that I don't need this proof as much as I thought, so I am just going to put this on the 'back burner' (if I got that right) for now. Thanks for the help!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
