The main function in an Interrupt of a Computer
  • Thread starter Thread starter Cruger
    Computer Function
Interrupts in operating systems are signals generated by hardware, such as drivers, that temporarily halt the currently executing thread, allowing the system to respond to events. This process involves saving the program state to an interrupt stack and invoking an interrupt handler, which is a routine designed to manage these signals. There are two primary methods for handling input in microprocessors: interrupt-driven input and polling. Interrupt-driven input allows hardware signals to trigger the operating system to execute an interrupt subroutine, which typically handles tasks like buffering input. In contrast, polling involves the operating system continuously checking the state of input pins, which can ensure that all inputs are treated with equal priority but is less efficient and rarely used. The discussion highlights the trade-offs between these methods, noting that while interrupts can lead to prioritization issues, polling can provide a more uniform handling of inputs, akin to a round-robin discussion format in a classroom setting.
Cruger
Hi there,
Can somebody explain me the main function in Interrupt in the operating System?
Technology news on Phys.org
An interrupt (like from a driver) generates an OS signal. The currently executing thread is interrupted, and the program state (registers, usermode stacks, and program pointer) are saved - usually to the interrupt stack.
The function doing this is called an interrupt handler.[/color] These guys live in microcontroller firmware, device drivers, and parts of the OS kernel.
Likes 1 person
There are two classic ways for microprocessors/processors/CPU's to receive input. One is to allow hardware signals to "interrupt" the operating system, which causes execution to jump over to an "interrupt subroutine" for a bit, then return to the operating system. The interrupt subroutine will probably be placing input characters in a buffer, or some similar thing.
The alternatively to interrupt-driven inputs is polling. With a microprocessor, it may be possible to "turn off" most interrupts, and instead, the operating system can be programmed differently, so that it runs a loop which periodically polls each input pin to see it's state. In a polling situation, the logic that was in the interrupt service routine is now right inside the OS and executes right after the polling of that pin.
Polling is rarely used. We had to use it in telecom, sometimes, when handling really fast bit streams in fiber optics communications. That's because we had to make sure that nothing could "interrupt" the timely handling of bit pushing. The risk of an interrupt-driven system is that interrupts are prioritized, so if a high-priority interrupt happens too frequently, the lower-priority interrupts will never execute. Polling allows a way to guarantee that all input pins will be treated with approximately the same priority, simply by making sure that whatever is done at each pin does not take to long before you go on to the next pin.
So...think of a classroom where anyone is allowed to speak. Some people will interrupt a lot, and quieter folks will get little chance to say anything. Then think of a round-robin situation, where everyone is given a chance to speak (for say, a maximum time of one minute). It is easy to understand in that kind of scenario, but in my experience, students have had trouble grasping the difference in microprocessors.
Likes 1 person
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
What percentage of programmers have learned to touch type? Have you? Do you think it's important, not just for programming, but for more-than-casual computer users generally? ChatGPT didn't have much on it ("Research indicates that less than 20% of people can touch type fluently, with many relying on the hunt-and-peck method for typing ."). 'Hunt-and-peck method' made me smile. It added, "For programmers, touch typing is a valuable skill that can enhance speed, accuracy, and focus. While...
I had a Microsoft Technical interview this past Friday, the question I was asked was this : How do you find the middle value for a dataset that is too big to fit in RAM? I was not able to figure this out during the interview, but I have been look in this all weekend and I read something online that said it can be done at O(N) using something called the counting sort histogram algorithm ( I did not learn that in my advanced data structures and algorithms class). I have watched some youtube...
