Calculating Initial Charge of Identical Objects Using Coulomb's Law
  • Thread starter Physicsit
  • Tags
    Variable
Be sure to use the negative version of the quadratic formula (because of the -q1^2 term). Note that q2 will be the same size as q1, but with the opposite sign. In summary, two objects with different charges initially attract each other with a force of 1.20 N. After being brought into contact and returned to their initial positions, the objects now repel each other with a force equal to the initial attractive force. To find the initial charge on each object, Coulomb's law is used, where the charge is shared equally between the two objects. This leads to two equations, one for the sum of the
Physicsit
Ok this seems easy enough but I am missing something
Two objects are identical and small enough that their sizes can be ignored relative to the distance between them, which is 0.200 m. In a vacuum, each object carries a different charge, and they at-tract each other with a force of 1.20 N. The objects are brought into contact, so the net charge is shared equally, and then they are returned to their initial positions. Now it is found that the ob-jects repel one another with a force whose magnitude is equal to that of the initial attractive force. What is the initial charge on each object?
Coulumbs law states
that
f=k * q1*q2/r^2
f is clearly given
r is clearly given
k is a constant 8.99*10^9
1.20=8.99*10^9 * q1*q2/.200^2
where do q1 and q2 come into the picture?
Well, it says that the charge is shared equally between the two objects, so just call the charge on each object q.
Then
F = k ((q * q)/r2) = (kq2)/r2
Now re-arrgange to find q:
q2 = (Fr2)/k
and
q = ±√[(Fr2)/k]
Since it didn't state whether the charge was positive or negative.
I'll leave you to compute the answer.
Whoops. It appears that I didn't actually solve the problem. But I think you can get the two charges' sum and product from this and you might be able to find them that way.
Right. Call the final charge on each q; use Coulomb's law to find q.
If the original charges are q1 & q2, you know what the must add up to (2q) and what their product must be (-q2). Do a little algebra and you'll figure them out.
So does this look correct
So does this seem correct
f=k(q^2/r^2)
q = +/-squareroot([(Fr2)/k])
q=+/-squareroot([(1.20*(.200^2))/(8.99*10^9)])
q=+/- 2.31*10^-6
it would appear so because
8.99*10^9*(2.31*10^-6*2.31*10^-6)/.200^2 =1.20N
so Is this the right way to do it?
Not quite.
q=+/- 2.31*10^-6
This is true, but you're not finished. (Better make it +/- 2.311*10-6).
Not only does
q1 ≠ q2
but
q1 ≠ -q2
Do you see why?
If
q1 = -q2
then after the objects touch the final charge q would be 0 and there would be no electrostatic force between them.
Kind of lost then
I am not sure where to go with it then
I would have thought q1 = -q2
I am not sure how to solve for q1 and q2
with q=+/- 2.311*10^-6
it says that the objects are identical and initialy they repel each other so they have to be opposites
so I am not sure
why q1 cannnot = - q2
it would seem that how it should be since
they objects are identical except for the charge
I thought gnome explained this point well. When the two objects touch, they will distribute the charge between them equally. We know there must be a non-zero charge (q) on each object after they touch since they repel. So q1 cannot equal -q2: since, if they did, there would be no charge on either object after they touch. Do not continue until you understand this point.
The objects are identical, but not their charges. All you can deduce from the fact that they initially attract is that the two charges (q1, q2) are opposite in sign. You cannot conclude that the magnitudes are equal.
so I am not sure
Read the above carefully.
To solve for q1 & q2:
First find q (the final charge on both objects).
Then consider these two conditions that q1 and q2 must satisfy:
q1 + q2 = 2q (this comes from the fact that the total charge will distribute equally after touching)
q1 x q2 = -q2 (this comes from the fact that the force is equal, but opposite, before and after touching; look at Coulomb's law)
Combine these two equations and solve for q1 & q2. But don't waste time solving until you understand where these two equations come from and what they mean.
Yes, the objects are identical except for the charge.
And since they ATTRACT each other, one must be positive and the other must be negative.
So let one initial charge be X and the other one Y. One of these numbers is negative, but you'll worry about that later. Meanwhile just call them X and Y.
Since they are identical except for the charge, if one has charge X and the other has charge Y, after they touch, the final charge q on EACH of them will be (X+Y)/2.
But if X = -Y, then (X+Y) = 0
and then each one would have 0 charge and there would be no force between them.
So, you have two equations and two unknowns. Messy equations, because of the numbers you're dealing with, but its still just algebra at this point. You already solved for q, and you know that
X + Y = 2q
so that's one equation.
The other one is your original equation:
KXY/r2 = 1.2
You'll end up with a messy quadratic equation to solve.
Sorry, I switched to X and Y to avoid typing all those subscripts. Hope that didn't confuse you.
Note that there is no contradiction between Doc Al's second equation and mine.
Remember, way back when you solved for q, you said:
q2 = (1.2 * r2)/k
If you rearrange my second equation slightly you get:
XY = (1.2 * r2)/k
and I said that either X or Y is negative.
So XY = -q2
I think I understand
Thanks for all the help I think I got it now
We know that
q1 + q2 = 2q
and
q1 x q2 = q ^2
we found q earlier 2.311*10^-6
so
q^2 = 5.34*10^-12
2q = 4.66*10^-6
so
5.34*10^-12=q1 * q2
4.66*10^-6 = q1 +q2
so
4.66*10^-6 - q1 =q2
so
5.34*10^-12=q1 * (4.66*10^-6 - q1)
0=-q1^2 + 4.622*10^-6 - 5.34*10^-12
plug it all into the quadratic equation
q1 = - 4.622*10^-6 +/- squareroot(((4.622*10^-6)^2 -(4)(-1)(5.34*10^-12))/(2(-1))
q1= - 4.622*10^-6 + 3.27*10^-6
q1 = -1.352*10^-6
so
4.66*10^-6 - -1.352*10^-6 =q2
q2=5.974*10^-6
or
q1= - 4.622*10^-6 - 3.27*10^-6
q1= -7.89 * 10^-6
so
4.66*10^-6 - -7.89 * 10^-6 =q2
q2 =12.514*10^-6
Nope.
After you solve, you have to check your answer & see if it makes sense. At least, try multiplying q1 x q2 & see what you get.
Here's the problem:
We know that
q1 + q2 = 2q
and
q1 x q2 = q ^2
No! q1 x q2 = -q^2
That little minus sign makes a big difference.
As a result, this:
should be:
0=q12 - 4.622*10-6 - 5.34*10-12
1. What is Coulomb's Law?
Coulomb's Law is a fundamental law of physics that describes the force between two charged particles. It states that the force is directly proportional to the product of the charges and inversely proportional to the square of the distance between them.
2. How do you calculate the initial charge of identical objects using Coulomb's Law?
To calculate the initial charge of identical objects, you would need to know the charges of the objects and the distance between them. Then, you can use the formula Q = k * (q1 * q2) / r^2, where Q is the initial charge, k is the Coulomb's constant, q1 and q2 are the charges of the objects, and r is the distance between them.
3. What is the unit of measurement for charge in Coulomb's Law?
The unit of measurement for charge in Coulomb's Law is Coulomb (C).
4. Can Coulomb's Law be used to calculate the force between non-identical objects?
Yes, Coulomb's Law can be used to calculate the force between non-identical objects. However, the objects must have a point-like charge distribution and the distance between them must be much larger than their sizes.
5. How does the distance between two objects affect the force calculated using Coulomb's Law?
The force calculated using Coulomb's Law is inversely proportional to the square of the distance between the objects. This means that as the distance between the objects increases, the force decreases. Similarly, as the distance decreases, the force increases.
