The potential between a cone and a plate
6 replies · 3K views
zengodspeed1
[/B]
There is a conducting cone with angle α placed so that its vertex is normal to an electrically grounded plate, but electrically insulated from the plate and kept at a constant potential V. Find the potential V and the electric field in the region between the cone and the plate. End effects of the cone are neglected. V is independent of r and φ.
[/B]
If V is independent of r and Φ we know that the Laplacian reduces to:
we have the boundary condition:
Firstly, rearranging the Laplacian to solve for dV:
and integrating with respect to theta gives:
Using the boundary condition for the cone:
I don't really know how I can include the plane into my calculations. Any help would be very much appreciated.
What you have calculated is the potential difference between two coaxial cone ,where the inner one has a potential of ##V## at ##{\theta}_1## and the outer one has a potential of 0 at ##{\theta}_2##.
So check your calculation again,and find the right equation which fulfill the boundary conditions.Now let ##{\theta}_2 ## tend to ##\frac{\pi}{2}##.Then you will find the desired expression
zengodspeed1 said:
[/B]
[/B]
You can do this by using the boundary condition on ##V##,i.e,
$$V(\frac{\pi}{2}) =0$$
So by doing so I find that:
$$A = \frac{V_{0}}{ln(tan(\frac{\alpha}{2}))}$$
as B reduces to zero.
However I don't really understand what I am now doing with this information.
Now put these value in the Original equation,and you are done.
$$V(\theta) = V_{0} \frac{ln(tan(\frac{\theta}{2}))}{ln(tan(\frac{\alpha}{2}))}$$??
Now using this formula,you can find E too.
