Relativistic Boat: Does It Float or Sink?
  • Thread starter Thread starter genesic
    Boat Relativistic
genesic
This is a thought experiment that my friends and I (physics graduate students all) were pondering while we should have been doing Jackson homework. Consider a boat traveling at relativistic speeds. From the boat's frame, the water is contracted, and therefore is more dense. This would increase the buoyancy of the water and keep the boat afloat. However, from the water's frame, the boat is contracted, making it smaller and denser. Since a smaller amount of water is displaced, there is a smaller buoyant force, and so the boat sinks. So what actually happens?
The standard solution is that when gravity is also considered, the 'relativistic boat' tends to sink, e.g.: http://arxiv.org/abs/gr-qc/0305106" .
IMO, another (easy) way to look at it is that the radial acceleration caused by Earth is larger than 1g when the boat is moving relativistically in a transverse direction, i.e., when it has an angular velocity relative to Earth's center of mass.
<br /> \frac{d^2 r}{d t^2} = \frac {3 m{{\it v_r}}^{2}}{ \left( r-2\,m \right) r} + \left( r-2\,m \right) \left( {{\it v_\phi}}^{2}-{\frac {m}{{r}^{3}}} \right) <br />
as https://www.physicsforums.com/showpost.php?p=1046874&postcount=17", where v_{\phi} =d\phi/dt (geometric units). It is clear that any non-zero v_{\phi} causes an increase in {d^2 r}/{d t^2}.
[Edit: I erred when working out the limit when speed approaches c, so I took it out for now...]
[Edit2: I also realized that this can only work for a 'flat planet' scenario. For a normal, almost spherical planet, any relativistic speed will let the boat fly out of the water and possibly even reach escape velocity...]:wink:
I would like to know if the following is a valid approach to the problem. In order to convert pervect's polar coordinate analysis:
<br /> <br /> \frac{d^2 r}{d t^2} = \frac {3 m{{\it v_r}}^{2}}{ \left( r-2\,m \right) r} + \left( r-2\,m \right) \left( {{\it v_\phi}}^{2}-{\frac {m}{{r}^{3}}} \right) <br /> <br />
to a pseudo-Cartesian system for a 'flat planet' analysis, we can subtract the centrifugal acceleration r v^2_{\phi} and also get rid of the angular velocity by replacing it with a horizontal (x) velocity: v_x = r v_{\phi}.
If we take the initial radial velocity v_r = v_y = 0, we get the initial vertical (Cartesian) acceleration of a free-falling submarine, moving at v_x (with c=G=1):
<br /> <br /> \frac{d^2 y}{d t^2} = \left( r-2\,m \right) \left( \frac{{ v_x}^{2}}{r^2}-{\frac {m}{{r}^{3}}} \right) -\frac{{ v_x}^{2}}{r} = -\frac{m}{r^2}\left(1-\frac{2m}{r} + 2v_x^2\right)<br /> <br />
In a weak field (1g), but high speed Earth surface scenario, the vertical gravitational acceleration simply becomes: a \approx (1 + 2v_x^2) [/tex] g, with g ~ -9.8 m/s^2.
This is basically the same as the "submarine paradox" that was investigated by George Matsas. See http://arxiv.org/abs/gr-qc/0305106
<edit> Oops, I just noticed that Jorrie has already posted that link.. sorry
P.S.
In an old thread https://www.physicsforums.com/showthread.php?t=225573&highlight=submarine&page=5 I worked out this aproximate weak field equation for the force acting on a particle moving horizontally in a gravitational field :
F&#039; = \frac{GMm}{R^2} \frac{(1-Vv/c^2)^2}{(1-V^2/c^2)\sqrt{1-v^2/c^2}}
where:
V = horizontal velocity of the massive body (M) wrt the observer,
v = horizontal velocity of the test particle (m) wrt the observer,
M >> m.
This equation can be used to work out the buoyancy forces of the water or the force acting on the submarine, from the point of view of an observer at rest with the water or co-moving with the submarine.
kev said:
... I worked out this approximate weak field equation for the force acting on a particle moving horizontally in a gravitational field :
I agree - both approximations 'resolve' the submarine paradox by increasing the gravitational force.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
