Why can you only contract one field in the Wilson approach to renormalization?
nikol
When I am reading about the Wilson approach to renormalization in Chapter12.1 of Peskin & Shroeder I am wondering why are you allowed only to contract the \hat{\phi} field (this is the field that carries the high-momentums degrees of freedom)as they show in equation 12.10, I thought that we should add all the contractions, between all the 4 fields and here is the term they are making the example of:
\int \mathcal{D}\hat{\phi}exp\left(-\int d^{d}x \frac{\lambda}{4}\phi^{2}\hat{\phi}^{2}\right)
Here we are only doing the path integral over the ##\hat\phi## field, and not integrating over ##\phi##. You can only get internal lines in a Feynman diagram for fields you are integrating over. So we end up writing down Feyman diagrams where all the external lines are ##\phi## fields (because we only care about the interactions of low-energy particles) and all the internal lines are ##\hat\phi## fields (because we are only integrating over the high-momentum modes).
Thank you I think I almost understand. Another thing I am noticing is that while integrating over the high degrees of freedom \hat{\phi} the dependence of the large cutoff \Lambda goes into the coefficients (see for example the expression of \mu in formula 12.11 or for \lambda^{'} in 12.29). Are we to assume that we will no longer have any cases that as \Lambda->\infty that will not cause any of those coefficients to go to infinity? and if so is that only valid for theories that are renormalizable?
you will have the effect of it in higher order terms,where you will have two vertices for example.just see 12.13.
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
