The second derivative question
disfused_3289
Given (d^2)x/ (dt^2) = 2 for all t>= 0 and dx/dt= -5 and x= 4 when t= 0 find t when
a) dx/ dy= 0
b) x= 0
2. The attempt at a solution
a) Given (d^2)x/ (dt^2) = 2, then
dx/dt= 2x + c = -5
given dx/ dt= 0 then 2x + c= 0
c= -2.5 using 2x + c= 0 and 2x + c = -5
using dx/dt= 2x + c, t= x^2 + cx + d
where 0= 16 - 2.5 x 4 + d (using x= 4 when t= 0 )
where d= -6
Thus,
t= x^2 - 2.5x - 6
when dx/dt= 0 then x= 1.25 in 2x + c= 0 (c= -2.5)
subsituting x= 1.25 into x^2 - 2.5x - 6 gives t= -121/16,
however the answer seems to differ giving t= 2.5 when dx/dt= 0
How is this so?
b) not to sure as confused about a).
a) dx/ dy= 0
Perhaps you meant dx/dt=0?
dx/dt= 2x + c = -5
x and its derivatives are a function of t here, so from the second-order equation, you'll end-up at
\frac{dx}{dt} = 2t+C
given dx/ dt= 0
Was it? The question tells you what \frac{dx}{dt} is at t=0. Use this condition to find the constant of integration. With one more integration, you can find x as a function of t. The rest is just algebra.
where d= -6
Thus,
t= x^2 - 2.5x - 6
How is this so?
Part b should become clear once you rework part a.
disfused_3289 said:
Given (d^2)x/ (dt^2) = 2 for all t>= 0 and dx/dt= -5 and x= 4 when t= 0.
I think what you mean is:
Given \frac{d^2 x}{dt^2} = 2 , \quad \forall t \geq 0 and \frac{dx}{dt}(0) = -5 and x(0) = 4. You will then find that c is not -2.5.
And I now see that neutrino already told you that...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
