The squirrel jumps horizontally form the top of the 25m tall tree
  • Thread starter Thread starter Boop de Boop
    Form Tree
The discussion revolves around a physics homework question involving a squirrel jumping from a 25m tree and calculating its kinetic energy during the fall. Participants emphasize the need for the original poster to clarify the specific questions and provide details about their attempts to solve the problems. Guidance is offered to explore concepts related to kinetic energy and projectile motion, particularly focusing on the time of descent and horizontal motion. The forum encourages using existing resources, such as textbooks and online materials, to aid in understanding the principles involved. Overall, the thread highlights the importance of engaging with the material rather than seeking direct answers.
Boop de Boop
HI. I need help with my physics hw. I do not need the answers but need a general guidance on how to solve the problem. Would appreciate it alot!
So, are we supposed to guess what the question is?
No sorry. Here are the questions:
1. A squirrel jumps horizontally from the top of a 25 m tall tree with a speed of 8 m/s. What is the maximum kinetic energy of the squirrel during it`s entire trip down to the ground from the top of the tree?
2.If another squirrel of the same mass jumps straight upward from the ground well enough to get 4m off the ground and then falls back to the ground, what is the kinetic energy in the following locations and time:
a)3m above ground, on the way up
b)2m above ground, on the way down
c)1m above ground, on the way down
Hi and welcome to PF.
PF doesn't provide a simple question and answer service. The way to drive PF is firstly go to the homework section for homework. There is plenty of help available on that forum but you are required to show what you have done towards finding a solution so far. You are bound to have some notes or a textbook which will deal with bodies falling under gravity.
Hint: Whilst it is falling, it will be traveling forward with unchanged speed. Work out how long it will be before it hits the ground and that's the time it's traveling forward. . . . . . .
You can do the sums and/or Google will give you millions of links about trajectories at a school level.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
