How big and bright is the Sun seen from 120 AU?
In summary: So, Voyager is still accelerating because the Sun's size gets smaller and smaller the further away it is.
beginner49
Hi all
Currently, Voyager 1 is about 120 AU from the Sun. I wonder how big (or small) and bright would the Sun be seen from aboard this spacecraft . What approximate magnitude?.
Thanks in advance.
Astronomy news on Phys.org
beginner49 said:
Hi all
Thanks in advance.
Here, thanks to Caltech, is an artist's conception of the Sun from the vicinity of Sedna at 8 billion miles' (about 86 AU) distance:
It's still very bright, even at 120 au, at about magnitude -16.3 [the full moon from Earth is about -12.7. So you would easily be able to read a newspaper. It would, however, be a virtual point source at that distance.
BadBrain and Chronos
Thanks a lot for your replies. That of being able to read a newspaper is a very interesting detail.
thanks again.
On a related topic, I heard that voyager was still accelerating, why? What causes it to accelerate further?
The angular size θ of the Sun's disk is given by the formula:
[tex]
\sin \left( \frac{\theta}{2} \right) = \frac{R_S}{d}
[/tex]
where RS is the radius of the Sun, and d is the distance from it.
Because the distance is much larger than the Sun's radius, the sine is very small. Therefore, to a sufficient precision we may substitute:
[tex]
\sin \left( \frac{\theta}{2} \right) \approx \frac{\theta}{2}
[/tex]
provided that we measure the angle in radians. Nevertheless, we see that:
[tex]
\theta \approx \frac{2 R_S}{d} \propto \frac{1}{d}
[/tex]
the angular size is approximately inversely proportional to the distance. At 1 A.U. (the Earth), the angular size of the Sun is about 31' (arc minutes). Therefore, at 120 A.U. it is:
[tex]
\theta = \frac{31 '}{120} \times \frac{60 ''}{1 '} = 15.5 ''
[/tex]
that is about 15 arc seconds.
1. What is the distance between the Sun and 120 AU?
The distance between the Sun and 120 AU is approximately 8.72 billion miles.
2. How long does it take for light from the Sun to reach 120 AU?
It takes approximately 18 hours for light from the Sun to reach 120 AU.
3. How does the Sun appear from 120 AU?
The Sun would appear as a very small, bright point of light from 120 AU, similar to how stars appear from Earth.
4. Is the Sun visible from 120 AU?
No, the Sun would not be visible from 120 AU as it would be too far away and appear too small to be seen with the naked eye.
5. How does the temperature of the Sun change at 120 AU?
The temperature of the Sun decreases significantly as distance from it increases. At 120 AU, the Sun would have a temperature of approximately 50 degrees Fahrenheit, much cooler than its surface temperature of over 10,000 degrees Fahrenheit.
  • Astronomy and Astrophysics
