The temperature change of an ideal gas, Joule Kelvin expansion (const. enthelpy)
Gregg
This is the last part of the question. So far have been made to derive:
## \mu _{\text{JK}}=\left(\frac{\partial T}{\partial P}\right)_H=-\frac{1}{C_P}\left(\frac{\partial H}{\partial P}\right)_T ##
Then
##\left(\frac{\partial H}{\partial P}\right)_T=V - T \left(\frac{\partial V}{\partial T}\right)_P ##
It says you need to derive an expression for the temperature change as an integral over pressure.
##dT=\left(\frac{\partial T}{\partial P}\right)_HdP+\left(\frac{\partial T}{\partial H}\right)_PdH ##
At constant enthalpy ## dH = 0 ##.
## dT=\left(\frac{\partial T}{\partial P}\right)_HdP\text{=}-\frac{1}{C_P}\left(V-T\left(\frac{\partial V}{\partial T}\right)_P\right) ##
So I think the change in temperature will be:
## \text{$\Delta $T} =-\frac{1}{C_P} \int_{P_1}^{P_2} \left(V-T\left(\frac{\partial V}{\partial T}\right)_P\right) \, dP ##
Then it says derive an expression for the temperature change for an ideal gas.
## p V = n R T ##
## V = \frac{ n R T}{P} ##
## T\left(\frac{\partial V}{\partial T}\right)_P = \frac{ n R T}{p} ##
So it would seem the integral vanishes, and ## \Delta T = 0##
I don't think this is right.
Oh, but it is. The Joule-Kelvin coefficient μJK for an ideal gas is identically zero.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
