The work done by Thermodynamic processes
3 replies · 2K views
AhmedHesham
Hi gentlemen
I want to know the classification of thermodynamic processes according to which is higher than which in work done during either compression or expansion.
Thermodynamic processes like isentropic and isobaric.
Thanks
Hi Ahmed. (try to avoid gender specific salutations. PF welcomes people of all genders). Your question is not very clear. If you want to compare a compression of the same quantities of an ideal gas at the same initial volume and pressure to the same final volume using different processes, the ranking from highest to lowest amount of work done would be:
Adiabatic;
Isothermal;
Isobaric.
Since they begin at the same internal energy and since there will be no heat flow into the gas during compression, you can determine the amount of work done by comparing the change in internal energy using:
##W = \Delta U - Q## where W is the work done ON the gas and Q is the heat flow INTO the gas
Since there is no heat flow into the gas, Q ≤ 0.
The internal energy of an ideal gas is proportional to T and PV: ##\Delta U = nC_v\Delta T = (C_v/R)\Delta(PV)##
AM
AhmedHesham said:
Hi gentlemen
Thanks
I assume you are asking about reversible processes, correct?
Thank you very much guys for answering
I now understand it
