The workings of a Stirling engine
A Stirling engine operates by using a heat source to expand a gas, which then pushes a piston to do work. The gas is subsequently cooled at a heat sink, causing it to contract and return to the hot piston for re-expansion. The engine features two pistons that move out of phase, akin to sine and cosine functions, which enhances efficiency. While both pistons can be housed in a single cylinder, using two cylinders may simplify the mechanical design. Understanding the role of both pistons is crucial for grasping the engine's operation.
magicacid
Hi
As a school project, I want to construct a Stirling engine (particularly this kind : http://monsterguide.net/how-to-build-a-stirling-engine ). The execution is quite simple, but I do not fully understand the theoretical background.
Can someone give me an explanation?
Science news on Phys.org
Put simply, the engine uses a heat source to make a cold gas (such as air) expand. Expanding gas does work on a piston. The piston then pushes the air to a heat sink where it is cooled. Then the cooled air is pushed back to the hot piston where it is compressed and heated again.
See here: http://en.wikipedia.org/wiki/Stirling_engine
And here: http://en.wikipedia.org/wiki/Heat_engine
The key point to understand is that there are actually two pistons, which operate out of phase with each other, moving like graphs of ##\sin t## and ##\cos t##.
As the Wiki page shows, both pistons can be in one cylinder if you want, but it's probably mechanically simpler to have two cylinders.
Ah yes, I had forgotten to mention the very important 2nd piston.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
