The x components of the average accelerations?
33 replies · 6K views
emily081715
A(n) 8.5-kg object is sliding across the ice at 2.34 m/s in the positive x direction. An internal explosion occurs, splitting the object into two equal chunks and adding 12 J of kinetic energy to system. The explosive separation takes place over a 0.16-s time interval. Assume that the one of the chunks after explosion moves in the positive x direction. The x component of the average acceleration of this chunk during the explosion is afrontx, the x component fo the average acceleration of the other chunk during the explosion is arearx. What are the x components of the average accelerations of the two chunks during the explosion?
k=1/2mv^2
k=1/2(8.5)(2.34)^2
= 23.27J
23.27+12=35.27J
35.27/0.16= 220.4m/s^2
i've never done a problem like this
What values are required to compute the average acceleration? ( or what's the formula for it).
a=vf-vi/t
emily081715 said:
a=vf-vi/t
Right. You've been given ##t## and the initial velocity for both the pieces. You need to find their final velocities. There are two unknowns, so we'll need 2 equations to solve them. Can you see what the equations can be?
is one going to be the change in kinetic energy formula, and is the change momentum??
is the initial velocity for both pieces just 2.34?
Yes. You'll solve them to get the final velocities of both the pieces.
That's right.
That's right.
for the mass do i use 8.5, or need to divide that by two since its split equally?
When expressing the final momentum ( or kinetic energy) of the system, you'll have to divide it by two.
but on the initial side, it would just be 8.5(2.34) for momentume, and 1/2(8.5)(2.34)^2 for kinetic energy?
Yes, that's correct.
i got answers of 20.48 and 25.16. they're wrong
Your application of momentum conservation doesn't look right.
Suppose ##v## to be the initial velocity of the block and ##v_1## and ##v_2## be the final velocities of the two pieces. If the mass of the block is ##m##, the conservation principle gives $$p_i = p_f $$
$$ mv = \frac {m}{2}v_1 + \frac{m}{2}v_2 $$
This is your first equation. Similarly, for kinetic energy you'll get $$ \frac{1}{2}mv^2 + 12 = \frac{1}{2}\frac{m}{2}(v_1)^2 +\frac{1}{2}\frac{m}{2}(v_2)^2 $$
Solve these two equations for ##v_1##and ##v_2##. Use them in the formula for average acceleration.
i got answers of 74.56 and -74.31 for acceleration which are wrong
That doesn't match with my results either.
What values did you get for ##v_1## and ##v_2## ? Show your work.
In the third line, you have substituted for ##v_2## in terms of ##v_1##. You seem to have made a mistake there.
From the first equation(momentum conservation), we get ##2v = v_1 + v_2##. Or ##v_2 = 4.68 - v_1## . Use this in your second equation.
i got accelerations of -117.136 m/s^2 and 117.136m/s^2
is this correct?
emily081715 said:
is this correct?
I don't think so. You're one step closer though. The average accelerations you get must have the same magnitude and opposite signs. Show your work for the above result.
emily081715 said:
what did i miss?
In the third line you've written ##(4.68-v_1)^2## as ##( 21.9014-v^2_1)##. Are you allowed to do that?
Wouldn't you apply the ^2 to both numbers?
Or would you have to turn it into 21.904-9.36v1 -v1^2
i got accelerations now of 7.1 and -7.1 m/s^2
is this correct
