What Is the Difference Between Isotropic and Anisotropic Thermal Conductivity?
Isotropic thermal conductivity means heat flows equally in all directions, typical for bulk metals, while anisotropic thermal conductivity indicates direction-dependent heat flow, common in materials like composites. Anisotropic materials can exhibit unusual heat behavior, where heat does not follow the temperature gradient. Most materials are isotropic, and if specific anisotropic data is unavailable, it is advisable to ignore anisotropic options. Applications for isotropic materials include metals, whereas composites are prime examples of anisotropic materials. Understanding these differences is crucial for accurate thermal modeling in engineering applications.
sml2010
Hi to all
Can some one help me for below question:
What is different between "isotropic thermal conductivity" with " anisotropic thermal conductivity" ?
where and when we must use isotropic or anisotropic ?
which one is more accurate?
I solve an example in a FEM software and it is used anisotropic for thermal conductivity.
http://i813.photobucket.com/albums/z...Untitled-2.jpg
Please help me for difference and application of these two thermal conductivity method.
Thank you
If the thermal conductivity is not the same for every direction, then it is anisotropic.
It is isotropic if all directions are equivalent for heat flow. This the most common case (bulk metals are isotropic).
"Anisotropic" means the thermal conductivity of the material depends on the direction the heat flows through the material. It can also cause strange behaviour where the heat does not flow in the same direction as the temperature gradient.
Most common materials are isotropic. If your material data doesn't include anisotropic thermal properties, just ignore the option.
To respond to the question "which one is more accurate": That's the wrong question... Like Dr L and AlZero said, anisotropic means the material properties are direction dependent.
For applications:
1. Bulk metals (extruded, cast, forged) are considered isotropic for stiffness and conductivity.
2. Composites are the best example of anisotropic materials. Search for ThermalGraph Fabrics.
Thank you very much of all dear my friend that help me and post a reply here
thank you
some typical anisotropic thermal conductivity used for cooling:PCB/graphite...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
