Thermal expansion of a copper cylinder
The thermal expansion of a copper cylinder is calculated using the formula delta v = Beta * vo * (delta T). In this discussion, the initial temperature is 20.0 degrees Celsius, and the volume increase of 0.150% leads to a final temperature of 49.41 degrees Celsius. The calculation involves manipulating the equation to find the coefficient of volumetric expansion (Beta) as beta = dv / (vo * dt). Both participants confirm that the derived temperature is correct.
  • Understanding of thermal expansion concepts
  • Familiarity with volumetric expansion equations
  • Knowledge of the properties of copper
  • Basic algebra for manipulating equations
  • Research the coefficient of volumetric expansion for different materials
  • Learn about the applications of thermal expansion in engineering
  • Explore advanced thermal expansion calculations involving varying temperatures
  • Study the effects of temperature on material properties
Students studying physics, engineers working with thermal systems, and anyone interested in material science and thermal properties of metals.
dan_and_sim
A copper cylinder is initially at 20.0 degrees c At what temperature will its volume be 0.150 % larger than it is at 20.0 degrees c
delta v = Beta vo (delta T)
dv= beta vo dt
ive found an answer of 49.41 degrees c
I believe its from manipulating the second equation to
beta = dv / (vo dt)
does this seem right?
any help here would be great thanks in advance
Yeah I got the same answer, MP says it's right!
  • · Replies 67 ·
  • · Replies 16 ·
