Thermal Expansion of a copper sphere
The discussion focuses on calculating the common temperature at which a copper sphere will pass through a hole in an aluminum plate, utilizing the coefficients of linear thermal expansion for both materials. The coefficients are 23 x 10-6 °C-1 for aluminum and 17 x 10-6 °C-1 for copper. The correct approach involves solving the equation for ΔT and then adding the initial temperature of 20 °C to find the final temperature, which is 869.62 °C. The calculations presented were mostly accurate, but the initial temperature needed to be incorporated into the final result.
  • Understanding of linear thermal expansion principles
  • Familiarity with coefficients of linear expansion
  • Basic algebra for solving equations
  • Knowledge of temperature scales and conversions
  • Study the formula for linear thermal expansion: L(final) - L(initial) = a(T(final) - T(initial))
  • Research the significance of coefficients of linear expansion at different temperatures
  • Learn how to apply thermal expansion concepts in engineering applications
  • Explore the properties of materials like copper and aluminum in thermal contexts
Students in physics or engineering, material scientists, and anyone interested in thermal properties of materials and their applications in real-world scenarios.
ElBell
Please help with the below question: I have given my attempt below!
"A copper sphere of radius 2.000 cm is placed over a hole of radius 1.990 cm in an aluminum plate at 20 deg. C. At what common temperature will the sphere pass through the hole?"
My answer:
((∆T(23* 10-6)(0.01990)- .00010 = ∆T(17* 10-6)(0.02)
((∆T(23* 10-6)(0.01990) - .00010 = ∆T(17* 10-6)(0.02)
(∆T x 4.577x10^-7) – 0.00010 = (∆T x 3.4x10^-7)
- 0.00010 = (∆T x 3.4x10^-7) – (∆T x 4.577x10^-7)
-0.00010 = ∆T x -1.177 x 10^-7
∆T = 849.62
Do my equations and calcs look correct? I believed the answer was in the high 700's range...I also don't know how to bring the 20 degrees into it?
HELP!
Explain what you did please. Were the thermal expansion coefficients given for 20 °C or for for 0 °C?ehild
Sure!
First, I found out that the coefficients of linear expansion were 23* 10^-6 for aluminium and 17* 10^-6 for copper.
Then I formulated a linear equation using these coefficients, to try and find the missing temperature.
The left side of the equation, I also added the difference between the two sides- which is .00010.
I think went about solving the equation, but I am not confident in it being right!
Your equations were confusing with that superfluous number of parentheses. The result for ∆T is correct, but add 20°C to get the common temperature, and round it to the significant digits and write out the unit.
ehild
No I haven't used the 20 degrees anywhere..thats the problem I don't know what to do with it.
So how do I work out the coefficients of 20 degrees? I have a table that gives 'typical average values' of each substance, with the coefficient given under the heading a(degrees celsius^-1).
What does that mean?
What was the formula you learned for the linear thermal expansion of solids? Was it the same as this one:
L(final)-L(initial)=a(T(final) -T(initial))
T(final) -T(initial) is abbreviated as ΔT.
You calculated ΔT. Add the initial temperature to it, and you get the final temperature.
ehild
Thanks very much for your help. I got the idea for the equation from another post as one wasnt given on my assignment.
I am guessing I add 849 degrees to 20 degrees to get my final result?
Thanks again, much appreciated!
Yes, add it!
ehild
9K
