Thermite reaction on stove top?
  • Thread starter Thread starter bork2
    Reaction Thermite
The discussion centers on the color change of a cast iron grate on a gas stove, which transitioned from black to light gray after using an old aluminum pot. Participants clarify that this change is unlikely to be due to a low-grade thermite reaction. Instead, they explain that gas flames have varying areas that can oxidize materials, leading to color alterations without the presence of rust. The thermite reaction, which involves aluminum and iron oxide, requires specific conditions, including the presence of rust and high temperatures to initiate. Since no rust was observed, the likelihood of a thermite reaction occurring is dismissed. The conversation emphasizes the chemistry of gas flames and the properties of aluminum in relation to oxidation and reaction initiation.
bork2
Gas stove with 16000 btu output and cast iron grate (non coated)---using an old aluminum pot (non anodized, etc). The grate has changed from black (no apparent rust) to a light gray color. Was there some type of low grade thermite reaction here?? Any comments or thoughts on this? Thanx
Chemistry news on Phys.org
A lot depends on what you mean by
But in general - no. Gas flame has different areas, reducing and oxidizing, that's perfectly enough to change the color on the iron grate.
With the Thermit reaction, there is, in addition to metallic iron, the formation of aluminium oxide, which you do not mention seeing. It has been known for explosions to occur when an aluminium fuel nozzle is banged against a rusty iron tank filler.
A thermite reaction once it starts is relatively easy to detect because in the redox reaction, fully consumes one of the reagents (rust) leaving behind molten iron. No rust, no thermite. Essentially, aluminum is burnt using the oxygen not in the air, but in the iron. But for this to occur, there has to be a good supply of rust and both it and the aluminum must be extremely granular to allow for the mixing of the two reagents so that the molecules of the oxide are close and readily available to the element. Remember that Al undergoes passiviation and the getting the reaction started to begin with is difficult and requires very high temperatures, like the burning of a magnesium ribbon.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
