Thermo cycles with only T and mol
  • Thread starter Thread starter bmartz
    Cycles Thermo
The discussion revolves around calculating the efficiency of a three-step thermodynamic cycle involving an ideal diatomic gas. The first step involves heating the gas at constant volume, while the second step is an isothermal expansion, and the third step is a constant pressure contraction back to the original volume. The user is attempting to determine the total work and heat flow but is struggling with the isothermal expansion due to a lack of initial or final pressure or volume values. They consider using unknown variables for pressure or volume to simplify the calculations, hoping that these will cancel out in the end. The conversation highlights the challenges of applying thermodynamic equations without complete data.
bmartz
A three-step cycle is undergone by 3.8 mol of an ideal diatomic gas:
(1) the temperature of the gas is increased from 210 K to 550 K at constant volume;
(2) the gas is then isothermally expanded to its original pressure;
(3) the gas is then contracted at constant pressure back to its original volume.
Throughout the cycle, the molecules rotate but do not oscillate. What is the efficiency of the cycle?
Q=nCvΔT
Q=nCpΔT
Cv=5/2 R
Cp=7/2 R
W = nRTln(V2/V1)
ε=Wnet/QH
I know I need to find the total work and heat flow in. For step one it is easy enough, W=0 and Q=nCvΔT.
I'm stuck at step 2. I know that since it is isothermal ΔEint is 0, so Q=W. I am trying to calculate by:
W = nRTln(V2/V1)
But without any initial or final pressure or volume values I am lost.
Assume the problem as stated gives all the required information. Can you just let either the initial pressure or volume equal to an unknown with the hope that it will cancel out in the end? Just a thought.
