Thermochemistry (Enthelpy) queery
  • Thread starter Thread starter Yehia11
    Thermochemistry
The discussion centers on the relationship between internal energy and enthalpy, particularly in the context of thermodynamic processes. It highlights that the change in internal energy is calculated as the heat change minus the work done due to pressure and volume changes. However, at constant volume, the pressure-volume work becomes negligible. In contrast, enthalpy is defined as the sum of internal energy and the work associated with expansion (H = U + PV). The preference for using enthalpy in calculations is attributed to the practicality of maintaining constant pressure in experiments and processes, making it a more convenient measure for heat changes in many scenarios.
Yehia11
I know that: Change in Internal Energy = Heat change - (pressure X change in volume)
and at constant volume PV is negligable.
But i heard that ENTHALPY is like internal energy but at constant PRESSURE, so PV becomes negligable and enthalpy = heat change - (PV) PLUS (PV) = heat change.
How come at constant pressure, we just use enthalpy (heat change)??
I hope you understood the question, help is very much appreciated! thankyou!
Chemistry news on Phys.org
Enthalphy and internal energy are two similar yet different things. Enthalpy is defined as the sum of internal energy and work due to expansion, that si:
H = U + pV
We usually use enthalpy because it is easier to keep pressure constant than to keep volume constant. Its just a matter of convenience.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
