Thermodynamic temperature derivation
The discussion centers on the derivation of the thermodynamic temperature scale, emphasizing that heat transfer between reservoirs is a function of their temperatures, expressed as Q1/Q2=Φ(T1,T2). One question raised is whether it is an assumption that the function Φ maintains its form across different temperatures, to which it is clarified that Φ can indeed change its value with temperature variations. Another point of inquiry is the expression of Φ(T1,T2) as ψ(T1)/ψ(T2), which is acknowledged as an underlying assumption in the derivation process. The conversation references a specific section in a thermodynamics textbook for further clarification. Understanding these concepts is crucial for grasping the foundations of thermodynamic temperature scales.
kelvin490
In deriving thermodynamic temperature scale, it uses the concept that heat transfer between two reservoirs is the function of the reservoirs' temperatures. i.e. Q1/Q2=Φ(T1,T2). And then further express that Φ(T1,T2)=ψ(T1)/ψ(T2).
I have two questions, 1. Is it a hidden assumption that the function Φ doesn't change its form for different temperatures? i.e. for different reservoirs we just plug in different temperatures Φ(T1,T2), Φ(T3,T4) but it can never be some other functions for different temperatures. Why?
2. Why Φ(T1,T2) can be expressed as ψ(T1)/ψ(T2)? Any underlying assumptions?
Science news on Phys.org
Your question doesn't make any sense. The fact that it depends on temperatures means that Φ can change its value for different temperatures. It can.
My understanding is this is an underlying assumption, at least in this presentation of the material.
See Section 5.3 in Introduction to Chemical Engineering Thermodynamics by Smith and Van Ness.
Chet
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
