Thermodynamics: Calorimeter problem
To solve the calorimeter problem, the heat gained by the calorimeter and water must equal the heat lost by the steam. The equation Qsteam = Qcalorimeter + Qwater is correctly set up, but it requires accounting for two stages of heat transfer from the steam: the latent heat of condensation and the cooling from 100°C to 50°C. The latent heat of steam should not be directly plugged in without considering these stages. The calculations show that the total heat required to raise the temperature of the calorimeter and water to 50°C is 7638.6 cal. Understanding these steps is crucial for accurately determining the mass of steam needed.
petefic
A 50.0g copper calorimeter contains 250g of water at 20 deg celsius. How much steam must be condensed into the water if the final temperature of the system is to reach 50 deg celsius?
Can someone explain how to find the Ls? I was told that just plugging in the latent heat of steam (2.26*10^6) is incorrect.
ms * Ls = (mc * cc * dT) + (mw * cw * dT)
ms * Ls = (0.05kg * 0.0924cal/g * (50deg-20deg)) + (.25kg * 1cal/g *(50deg-20deg))
ms * Ls = 7638.6cal
ms * Ls = 7638.6cal
You have to assume that the steam is at 100°C.
You have the right idea in setting up an equation that equates the heat flow into the 250 g of water and 50 g calorimeter to the heat flow out of an unknown mass of steam. But the heat flow from the steam occurs in two stages: 1. the release of the latent heat of condensation and 2. the heat lost in reducing its temperature from 100C to 50C.
AM
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
