Thermodynamics - Carnot Engine
The discussion focuses on the relationship between heat absorbed and rejected by reservoirs in an Ideal Gas Carnot engine, emphasizing the equations that define this relationship. For part (a), the user attempts to apply the Carnot efficiency formula but expresses uncertainty about its application. In part (b), the user struggles with calculating the temperature a house can maintain using a heat pump, ultimately arriving at a temperature of 275K, which they question for accuracy. The conversation highlights the challenges faced in understanding thermodynamic principles and the application of relevant equations. Assistance is sought for clarification and guidance on these thermodynamic concepts.
NavalChicken
(a.) For an Ideal Gas Carnot engine, what is the relationship between heat absorbed and rejected by the reservoirs and their temperature? If a heat pump is used to transfer this heat, what is the rate at which heat is added to the hot reservoir in terms of the temperatures of the reservoir and the work done by the pump?
(b.) A house is imperfectly insulated such that it can maintain a heat difference from its surroundings of 5K if it is heated solely by electrical power supplied to electric heaters. If the heaters are turned off and the same power is supplied to a heat pump that extracts heat from a reservoir at the same temperature of the surroundings, 270K, at what temperature can the house be maintained?
\frac{Q_H}{Q_C} = \frac{\theta_H}{\theta_C}
and
\frac{Q_H}{W} = \frac{\theta_H}{\theta_H - \theta_C}
For part (a.) I have the first equation I posted above and
\frac{dQ_H}{dt} = \frac{\theta_H}{\theta_H - \theta_C} \frac{dW}{dt}
which I'm not entirely sure is what the question was looking for
In part (b) I've tried quite a few different things and keep going in circles! I think, with a lot of messy substitution I get the temperature to be 275K. As it was before, which seems consistent with conservation of energy, but I'm not sure its actually right?
This looks like quite a basic question, so its quite embarrassing to be having problems with it, if anyone has any helpful advice that would be great. Thanks!
For example, one of the methods I used was:
Which, when \theta_H = 275 K and \theta_C = 270 K give \frac{dQ}{dt} = \frac{1}{55} \frac{dW}{dt}
But then I don't really know what to do with that?
anyone?
i need help with this one too!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
