Thermodynamics Cycle of Processes
In a thermodynamic cycle involving a fluid in a piston and cylinder, three processes are analyzed: A-B, B-C, and C-A. During Process A-B, 70kJ of work is done on the fluid, and 35kJ of heat is rejected. In Process B-C, 50kJ of heat is added to the fluid without a change in internal energy. The key point is that for a cyclic process, the total change in internal energy must equal zero, which helps determine the heat transfer in Process C-A. Understanding this principle is crucial for solving the problem effectively.
liamporter1702
A certain fluid of mass 1kg undergoes a cycle of processes in a piston and cylinder device as follows:
Process A-B: 70kJ of work done on the fluid. 35kJ of heat rejected to surroundings
Process B-C: 50kJ of heat transferred to the fluid. No change in internal energy of system.
Process C-A: 100kJ of work done by the fluid, fluid returns to the initial state.
Calculate the heat transferred to or from the fluid in process C-A.
I know that ΔU=Q-W is a relevant equation as I have been able to work out the other parts of this question that I have not written here with it, this part is actually the first part of the question but I am finding it the hardest to see what to do here :redface:
I don't know whether you are supposed to use some of the values listed in Process A-B again or am I missing something?
What you're missing is that, for a cyclic process, the sum of the three ΔU's has to be zero.
Chet
Likes 1 person
Ah thank you very much for pointing that out! Much appreciated!
