Thermodynamics: cylindrical figures contains a gas
The discussion revolves around calculating the change in internal energy for a gas in a cylinder with a piston. The initial conditions include a volume of 1 liter, pressure of 10^5 Pa, and temperature of 300 K, with a final temperature of 540 K after applying pressure. The internal energy change is expressed using the equation ΔU = (3/2)nRΔT, where n is the number of moles and R is the ideal gas constant. Participants clarify that the internal energy for an ideal gas depends solely on temperature, and the user calculates n as 0.0401, resulting in a change in internal energy of 24.5 J. The conversation emphasizes the importance of understanding the relationship between temperature and internal energy in thermodynamics.
mtayab1994
A cylindrical figures contains a gas and we have a piston that is capable of changing the gases volume.
Initial state: V0=1l P0=10^5p T=300°K
We pressurize on the piston that has a mass m=300g and a surface S=20cm^2.
The new temperature T1=540°K
Calculate the change in internal energy.
Well I know that the change in internal energy is: ΔU=W+Q or ΔU=-P1(V1-V0)
and that p=F/S. but since my teacher didn't explain the lesson well enough I have no clue on how to answer it. Any help would be very well appreciated.
i believe i would have to use this one right?
I would get: ΔU=p1(V0-V2)+Q right?
OK, I'll let you off the hook:
Internal energy for an ideal gas depends only on it's temperature.
\Delta U = \frac{3}{2}nR\Delta T
You know the change in temperature - it's given to you.
You need to find nR.
alright i'll give it a try right now.
I got n=.0401 by using the equation of ideal gases and i got a change of internal energy as 55J correct?
mtayab1994 said:
I got n=.0401 by using the equation of ideal gases and i got a change of internal energy as 24.5J.
Is this correct?
I've not done the math so I cannot tell you.
But it's numbers-in-numbers-out, hard to go wrong.
