Thermodynamics - efficiency question
The discussion centers on calculating the efficiency of a car engine using gasoline as fuel. The car burns gasoline at a rate of approximately 30,000 kcal per gallon and averages 41 km per gallon while requiring 25 horsepower. Initial calculations yield an efficiency of about 23.46%, but further analysis suggests a corrected efficiency of 24.4%. Participants emphasize the importance of accurate unit conversions and avoiding premature rounding in calculations. The conversation highlights the significance of algebraic representation in understanding thermodynamic efficiency.
N_L_
The burning of gasoline in a car releases about 3.0 x 10^4 kcal/gal. If a car averages 41 km/gal when driving 90 km/h, which requires 25 hp, what is the efficiency of the engine under those conditions?
I think I have an answer, but I'm not sure if it's correct.
1 horsepower = 746 watts
25 hp = 18650 watts
1 kcal = 4186 joules (watts / sec)
e = W / Qh = 1 - (Ql / Qh)
1 gal / 41 km at 91 km / h means that that 2.26 gallons will be used in one hour.
Since no temperatues are given I don't think that the 1 - Ql / Qh is needed...
Converting 30000 kcal / gal to watts I get 34883 joules/sec. Since 2.26 gal are used, I multiplied the above by 2.26 to get 78836.
Dividing 18650 watts (from hp) by 78836 I got an efficiency of 23.46%.
25 hp = 18650 watts
You don't need to find Qc but it is just:Qc = Qh - W. You don't need temperatures to find this.
You should state your answer algebraically so you and others can follow the physical reasoning. ie:
\eta = W/Q_h = (dW/dt)/(dQ_h/dt)
Your answer is almost right. I get 2.195 gal/hr (90/41) not 2.26.
dQ_h/dt = 2.195 * gal/hr = 3 x 10^4 * 2.195 * 4.186 KJ/hr = 2.76 x 10^8 J/hr = 7.66 x 10^4 J/sec
dW/dt = Power = 25 * 746 J/sec = 1.87 x 10^4 J/sec
So:
\eta = 1.87/7.66 = 24.4%
AM
I have not rigorously checked your answer, however the efficency appears reasonable for a car, just beware of rounding too early in your calculations, this could induce significant errors. For example you obtained 78836 watts for the input power of the engine, however I obtained 78798\frac{2}{3}.
Just a small point that I sould point out is that here you said;
I'm sure this is just a typo, but this should be joules = watts * sec. Power is work done (energy) divided by time, therefore it follows that energy is the product of power and time.
~H
Sorry AM, didn't see your post. I sould learn to type faster :wink:
Thank you.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
19K
