What Is the Specific Heat Capacity of Ethanol?
The discussion revolves around calculating the specific heat capacity of ethanol when mixed with water. A student presents a problem involving 41.8g of ethanol at 15.8°C mixed with 50.7g of water at 49.2°C, resulting in a final temperature of 28.4°C. The equation used to find the specific heat capacity of ethanol is derived from the heat transfer principles, leading to a rearrangement and solution for the variable X. The student notes that the calculation yields a correct answer but questions the complexity of the method for a multiple-choice question. The conversation concludes with the acknowledgment that the signs in the equation appear to be correct, affirming the validity of the result.
theLiminator
A student mixes 41.8g of ethanol at 15.8 C with 50.7 g of water at 49.2 C. If the resulting temperature of the solution is 28.4 C, what is the specific heat capacity of the ethanol?
Given heat capacity of water already.
let X = heat capacity of ethanol
38.4C = (41.8*15.8*X - 49.2*50.7*4.184)/(X*41.8+50.7*4.184)
i just rearranged and solved for X. I did get the correct answer, however it seems too ugly for a simple MC question.
I guess 38.4C is meant to be 28.4C. If so it looks OK to me - that is assuming you got signs right, but if the result is correct you probably did. And I am not aware of a simpler method of getting the answer.
methods
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
