How Do You Calculate the Necessary Collector Area for a Solar Water Heater?
In summary, the conversation discusses the use of a solar water heater and its components, including rooftop collectors and transparent covers. The question at hand involves determining the necessary collector area to heat water in a 200-L tank from 20°C to 40°C in 1.0 hour, given an incident sunlight intensity of 700 W/m^2 and assuming 80% energy loss. The conversation also mentions relevant equations, such as Q = mcdelta t and delta t = iR, for calculating energy and temperature changes.
Ishida52134
139
In a solar water heater, energy from the Sun is gathered by rooftop collectors, which circulate water through tubes in the collector. The solar radiation enters the collector through a transparent cover and warms the water in the tubes. Assuming that 80% of the incident solar energy gets lost (i.e; it does not go into heating the water), what collector area is necessary to take water from a 200-L tank and raise its temperature from 20 C to 40 C in 1.0 h? The intensity of incident sunlight is 700 W/m^2.
Q = mcdelta t
delta t = iR
Welcome to PF.
What have you tried?
Where are you stuck?
I've tried applying those formulas and combinations of them. I don't really understand the problem.
What is the definition of power?
How much energy does it take to raise the temperature of 1 kg of H2O by 1°C
To solve this problem, we can use the equation Q = mcdelta t, where Q is the energy absorbed by the water, m is the mass of the water, c is the specific heat capacity of water, and delta t is the change in temperature. We can also use the equation delta t = iR, where delta t is the change in temperature, i is the intensity of incident sunlight, and R is the collector area.
First, we need to calculate the energy absorbed by the water. We know that the specific heat capacity of water is 4.186 J/gC, so we can convert the volume of water (200 L) to mass using the density of water (1 g/mL). This gives us a mass of 200,000 g. Plugging in the values, we get Q = (200,000 g)(4.186 J/gC)(40 C - 20 C) = 16,744,000 J.
Next, we can calculate the change in temperature using the equation delta t = iR. We know that the intensity of incident sunlight is 700 W/m^2, and we want to raise the temperature by 20 C in 1.0 h, which is equivalent to 3600 seconds. Plugging in the values, we get 20 C = (700 W/m^2)(R)(3600 s), which gives us a collector area of 0.007 m^2.
In conclusion, to raise the temperature of water in a 200-L tank from 20 C to 40 C in 1.0 h with an 80% energy loss, we would need a collector area of 0.007 m^2.
What is thermodynamics?
Thermodynamics is the branch of physics that deals with the study of heat and its interconversion with different forms of energy.
What are the laws of thermodynamics?
The laws of thermodynamics are fundamental principles that govern the behavior of energy in a system. The first law states that energy cannot be created or destroyed, only transferred or converted. The second law states that in any energy transfer or conversion, some energy will be lost as heat, making the process irreversible. The third law states that the entropy of a pure, perfect crystal is zero at absolute zero temperature.
What is the difference between heat and temperature?
Heat is the total energy of molecular motion in a substance, while temperature is a measure of the average kinetic energy of the molecules in a substance. In simpler terms, heat is the amount of energy present, while temperature is the intensity of that energy.
What is an example of the first law of thermodynamics?
An example of the first law of thermodynamics is when a ball is thrown, the kinetic energy of the ball is converted into potential energy as it reaches its highest point. The total energy remains the same, but it has been converted from one form to another.
What is an example of the second law of thermodynamics?
An example of the second law of thermodynamics is the fact that it is impossible to create a completely efficient engine. Some energy will always be lost as heat, making the process irreversible.
  • Mechanical Engineering
