Thermodynamics regarding ideal gases and the absolute zero.
Achieving temperatures below absolute zero is deemed impossible, as absolute zero represents a state where molecular motion ceases. Ideal gases contract linearly as temperature decreases due to the direct relationship outlined in the Ideal Gas Law (pV=nRT). In contrast, real gases do not contract linearly because intermolecular interactions become significant at lower temperatures, affecting their behavior. Absolute zero serves as a common endpoint for both real and ideal gases due to the fundamental principles of thermodynamics. For further insights, exploring the canonical distribution and energy equations like E=kT can provide deeper understanding.
spanky489
Hello colleagues, I have a seminar that i need to turn in a weeks day from now.
My professor listed the following questions, guidelines that I should lean on:
1) Is it possible to achieve a temperature bellow absolute zero (-273,15)
2) An ideal gas contracts linearly when decreasing temperature towards absolute zero, why?
3)A real gas doesn't contract linearly,why? it has more variables than the ideal gas, but this is not the complete answer.
4)Why is the absolute zero temperature the common ending point for both(real and ideal)
colleagues, i think the answer here lies in the specter that lies deeper than what most engineers abide by. We must go deeper than continuum, i think all the answers can be interpreted through the molecular level. And now I am asking you if you know any good links that could help me with my seminar. Also if you have any helpful information feel free to share.
Science news on Phys.org
Nope, all these questions are answerable without making use of statistical thermodynamics (i.e. the 'molecular level').
please post something constructive, a link maybe? or maybe care to elaborate on your statement.
Aside from the lack of evidence of sub-zero K (Kelvin) temperatures,
I think the OP should look to the canonical distribution for some information. There you could "experiment" with what would happen to the energy levels if you let them approach negative, or even zero.
You could also look to E=kT as well. Where E is total energy, k is the Boltzmann constant, and T is in Kelvin, what would happen if T < 0? Can we have a E less than zero? Can we have an E = 0?
For the second question, look to the Ideal-Gas Law.. figure it out yourself: pV=nRT
For number three, that's a fun one. I can think of a number of reasons why, depending on what level of Physics you are familiar with. I'd reckon that mentioning that interactions between particles at lower temperatures become non-negligible and so transitions between states (i.e. gas to liquid to solid) becomes important. Ideal-gas law doesn't allow for this.
4. I suggested it above I think.
It is impossible to achieve absolute zero temp. Because according to the Kelvin's observations, the volume & pressure of a gas becomes zero at -273.15. i.e
temperature is inversely proportional to volume & pressure. That's why he started measuring temperature from this point.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
