MattHorbacz said:
Why can that be used even though volume isn't constant?
Because U is a state function, and its change (ΔU) does not depend on the kind of process occurring. Furthermore, C
V is defined as
[tex]C_V = \left( \frac{\partial U}{\partial T} \right)_V[/tex]
And we know U only depends on temperature for ideal gases, so, for any ideal gas undergoing
any kind of process, ΔU will always be
[tex]\Delta U = \int_{T_1}^{T_2} C_V \ dT[/tex]
If C
V were constant, this equation simplifies to the one I previously posted.
Now, this is what may be confusing you:
If you want to calculate the heat transferred to or from the system in a
constant volume process you use
[tex]Q = \Delta U = \int_{T_1}^{T_2} C_V \ dT[/tex]
constant pressure process you use
[tex]Q = \Delta H = \int_{T_1}^{T_2} C_P \ dT[/tex]
But these equations apply only because Q = ΔU in a constant volume process, and Q = ΔH in a constant pressure process. However, for
any kind of process, the definitions of ΔU and ΔH are always the same. That is why, in this case, we are having an adiabatic process, wherein neither pressure nor volume are constant, but the definition of ΔU is always the same, so you use C
V regardless of the nature of the process.
I hope this helps clearing your doubts!
