Thick spherical shell Question.
The discussion revolves around calculating the total charge and electric field of a thick spherical shell with inner radius R, outer radius S, and uniform charge density d. For part A, the total charge Q is derived from the volume of the shell, yielding Q = d * (4/3)π(S^3 - R^3). In part B, the electric field is evaluated in three regions: it is zero for 0<r<R, follows E = (4πkρ(r^3 - R^3))/3r^2 for R<r<S, and behaves as E = kQ/r^2 for S<r, treating the shell as a point charge. The discussion emphasizes the need to express answers solely in terms of d, R, S, and π, rather than introducing Q in subsequent calculations. Utilizing Gauss' law is recommended for a more straightforward solution.
twinpair
A thick spherical shell with inner radius R and outer radius S has a uniform charge density d.(A) What is the total charge on the shell? Express your answer in terms of R, S, d, and π. (B) Express the electric field as a function of distance from the center of the sphere r, R, S, d, and the permitivity of free space p for each of the following regions: 0<r<R , R<r<S, S<r
E = kQ/r2
V=(4/3)πr3
(For part A)
Since its a thick shell the volume would be V = (4/3)π(S^3 - R^3)
and dV = Qenc => d=Q/V
so
d = 3Q/(4π(S^3 - R^3))
(For part B)
0<r<R
the electric field will be 0 because the electric field can't close on itself
R< r< S
E=kQenc/r2 = (4πkρ(r^3 - R^3))/3r^2
S<r
E = kQ/r2 because the sphere can be treated as a point charge and the electric field is symmetric on a sphere
Is this correct?
E = kQ/r2
V=(4/3)πr3
(For part A)
so
(For part B)
0<r<R
R< r< S
S<r
Is this correct?
Everything looks good. But note that for part A they want Q. And for the other problems, you must give the answer in terms of ##d , R, S ##
So for part A would it be Q = dv --> Q = d * (4/3)π(S^3 - R^3)
And for other problems what does it mean to give the answer in terms of d,R,S
That's correct.
What it means is that your answer must contain only those parameters (your answer cannot contain Q).
twinpair said:
And for the other problems, you must give the answer in terms of d,R,S
what does it mean to give the answer in terms of d,R,S?
Hello twinpair,
Welcome to Physics Forums! :smile:
E = kQ/r2
V=(4/3)πr3
(For part A)
so
That's not technically wrong, but it doesn't answer the question. You are already given the density, d. The problem statement is asking you to solve for the total charge, Q.
(For part B)
0<r<R
Correct. :approve:
R< r< S
That's the first introduction of ρ, the Greek letter "rho." Is that supposed to be d?
You're supposed to answer in terms of r, R, S, d and p.
Whatever the case, rather than fiddle with substitutions, I suggest starting over. Use Gauss' law.
This part of the problem is very straightforward if you start with Gauss' law; that way it doesn't require any fancy-schmancy substitutions.
S<r
That's also correct, but is using the wrong set of variables. You could make the substitution of k = \frac{1}{4 \pi p}, but as it turns out, the solution is actually easier to come by if you apply Gauss' law from start to finish, solving for E as the final step*. :wink:
*[Edit: although you can leverage the total charge found in part A.]
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
