Think about SR as different observers using different coordinate
  • Thread starter Thread starter daniel_i_l
    Coordinate Sr
daniel_i_l
Is it correct to think about SR as different observers using different coordinate systems depending on their speeds? This would meen that their measurements would differ since space, time, mass,etc.. measurements depend on the system used. I find it very easy to understand SR when I think about it this way. Is it correct?
You can definitely think about it that way, just keep in mind that the coordinate systems being used are a little funny, i.e. the invarient in Minkowsky space is \sqrt{t^2-x^2-y^2-z^2} or \sqrt{-t^2+x^2+y^2+z^2}, depending on whether the interval is timelike or spacelike, instead of \sqrt{t^2+x^2+y^2+z^2}, as one might expect from Cartesian space.
You can even represent the Lorentz transformation between refrence frames as a matrix, and then demonstrate that the matrix preserves lengths and angles (again, in the sense of Minkowsky coordinates) so that you can view it as being simply a rotation between different coordinate systems.
It is correct as far as it goes, but unless you go further and give the Lorentz transforms, or some equivalent statement such as the fact that the Lorentz interval is invariant for all observers, you have not uniquely identified SR.
You also have to note that the differing coordinate systems reflect the same underlying reality (covariance).
Thanks,
Well, obviously the coordunate system would have to rotate is such a way that the speed of light would be constant for all observers.
Not only the speed of light, but also other invariant quantities. For example, the spacetime interval between two events \Delta s = \sqrt{(c \Delta t)^2 - (\Delta x)^2 - (\Delta y)^2 - (\Delta z)^2} is the same in any inertial reference frame. Also the quantity m_0 c^2 = \sqrt{E^2 - (p_x c)^2 - (p_y c)^2 - (p_z c)^2} is the same in any inertial reference frame, for any object.
More generally, the magnitude of any four-vector is the same in all inertial reference frames, just as the magnitude of any ordinary "three-vector" stays the same when you rotate your (3-dimensional) coordinate system. An examples of a four-vector is the energy-momentum four-vector (p_0, p_1, p_2, p_3) = (E/c, p_x, p_y, p_z). Also, the "dot product" of two four-vectors, a_0 b_0 - a_1 b_1 - a_2 b_2 - a_3 b_3 is the same in any inertial reference frame.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
