This is seems like an easy question
  • Thread starter Thread starter neotriz
The discussion revolves around calculating the change in potential energy for a particle acted upon by a conservative force described by the equation Fx = (2x + 4) N. The user initially assumes that potential energy is zero since the motion is horizontal, but this assumption is incorrect. It is suggested that the user should apply the work-energy principle, where the work done by the conservative force relates to the change in potential energy (W = -ΔU). The conversation emphasizes the importance of using the correct equations to find the potential energy change as the particle moves along the x-axis. Understanding these concepts is crucial for solving the problem accurately.
neotriz
This is seems like an easy question...
A single conservative force acts on a 5.00 kg particle. The equation Fx = (2x + 4) N describes this force, where x is in meters. As the particle moves along the x-axis from x = 2.20 m to x = 6.60 m.
Calculate the change in the potential energy of the system
Since it just only involves horizontally, I thought the Potential Energy would be zero, but it's telling me it's wrong.
I think you should look up relevant equations, like how work done by a conservative force F will be W = -ΔU where ΔU is the change in the potential energy. So W = Fd (force*distance) or W = Fdcosθ...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
