Thought Experiment on perfect strings
Insanity
I've recently had this thought experiment, and wanted to share it.
My HS physics teacher had talked about "perfect" strings that had no mass, does not stretch, and is completely flexible when describing physics experiments. Using such a hypothetical string means it does not interfere with the experiment. It has no mass to alter momentum, does not stretch under stress and smoothly wraps around pulleys. In this thought experiment I adopted this.
Take a length of material that, much like the perfect string, has no mass and does not bend under stress. Balance or suspend it across a fulcrum, so that it appears like a see saw or teeter-totter. Like so.
Code:
____________
If its initial position is perfectly horizontal, and someone pushes down on one end , the other end rises up, correct? The answer, of course, is yes.
However the question I have been asking myself is, how much time passes before the other end rises up? As the material does not bend and has no mass for momentum be an issue, as near as I can determine myself, it rises up simultaneously as the opposite end is pushed down, or t=0.
Now, extend the length of the material to a light second (299,792,458 m). Again, push down on one of the ends and simultaneously send a photon/s down the length. The time for the photon/s to reach the opposite end (assuming vaccuum) is t=1 sec, while the time for the opposite end to rise remains the same, t=0. I cannot see how the time for the opposite end to move is anything but t=0 regardless of its length, or by how much force is applied. t=0.
If an observer was stationed at each end, they each would be aware when the opposite end was moved prior to the photon/s arriving. Simple, yet seems profound and yet almost not true.
feedback?
Congratulations, you've neatly outlined the argument for why there are no perfectly rigid bodies in the real world :biggrin: Your ideal material could not really exist.
When you push down on one end of the bar, the force is transmitted along its length by means of electromagnetic forces, which are carried by photons. So there's little difference between the "messenger photon" you'd send along next to the bar, and the ones that are carrying the "message" that one end has been pushed. Both signals travel at (or in the case of the bar's motion, below) the speed of light. As an observer stationed some distance to the side of the bar, you'd see it bend as the disturbance caused by the initial push propagates along its length. And consequently, the other end of a light-second-long bar would only begin to rise one second (or more) after the initial push.
Assuming one could see the other end, and the gravitational field is on a flat surface for the seesaw, it would be an incredible experience. You would hit the ground and still see your friend rising. Good thought experiment
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
