Three blocks, two pulleys, on a incline
The discussion revolves around a physics problem involving three blocks connected by pulleys, with one block on an incline and friction present. The key equations for analyzing the forces acting on each block include the sum of forces in both the x and y directions, which help determine the normal force and tension in the system. It is emphasized that the system shares the same acceleration, and each block should be evaluated individually to identify all acting forces. The net acceleration direction is influenced by the weights of the hanging blocks, with the heavier block causing the lighter block to move upward. Proper application of Newton's laws and free body diagrams is crucial for solving the problem effectively.
gap0063
The suspended 2.29 kg mass on the right is
moving up, the 1.3 kg mass slides down the
ramp, and the suspended 7.7 kg mass on the
left is moving down. There is friction between
the block and the ramp.
The acceleration of gravity is 9.8 m/s2 . The
pulleys are massless and frictionless.
[PLAIN]http://img816.imageshack.us/img816/6190/009q.png
What is the acceleration of the three block
system?
Answer in units of m/s2
The sum of Fx= N-mgcostheta=o => N=mgcostheta
The sum of Fy= mgsintheta-usN=0=> mgsintheta-us(mgcostheta)
are these the correct eqations for this?
You'll want to look at each block in isolation. The system will have the same acceleration.
What forces act on the two hanging blocks?
What forces act on the block sliding down the incline?
What direction is the net acceleration?
Hint: there are two tension forces.
For the mass on the incline, choose the horizontal axis as the x axis, and the axis perpendicular to the incline as the y axis. In which case you have your Fx and Fy equations reversed. Then once corected , this will give you the normal force acting on that one block on the incline. That's step one...then its free body, free body, free body diagrams! Answer jhae2.718 questions. Look at each block separately, identify alll forces acting, and apply Newton's laws.
For block on the left... the mass I'll call m1... the forces acting on it are T1 acting up and m1g acting down
For block on incline... the mass I'll call m2... the forces act on it in the y direction of N and m2g and in the x directuon fk and T2
For the block on the right... the mass I'll call m3... the forces acting on it are T1 acting up and m3g acting down
Since m1=7.7 and is bigger than 2.29 the acceleration is pulling m3 up and m1 down...
So if I use the equations I gave before for the block on the incline and just use
sum of Fy=T1-mg=0 => T1=mg
but where does the acceleration come in for m1 and m3?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 16 ·
  • · Replies 27 ·
9K
  • · Replies 19 ·
  • · Replies 22 ·
  • · Replies 68 ·
13K
