Solving Challenging Integrals: Strategies and Examples
  • Thread starter Thread starter Dustinsfl
    Integrals
The discussion focuses on ordering the integrals j, k, and l, defined as j=∫√(1-x^4), k=∫√(1+x^4), and l=∫√(1-x^8) over the interval [0, 1]. It is established that j is less than k since √(1-x^4) is always less than or equal to √(1+x^4) for x in [0, 1]. The comparison of l with j and k is suggested, with the conclusion that if x is between 0 and 1, the order is j < k < l. The discussion emphasizes that these integrals are not solvable in terms of elementary functions, but sorting them based on their integrands is feasible. Overall, the participants agree on the relationships between the integrals based on their behavior within the specified range.
Dustinsfl
j=\int\sqrt{1-x^{4}}
k=\int\sqrt{1+x^{4}}
l=\int\sqrt{1-x^{8}}
I am trying to figure out the order for example j<k<l. I don't know how to integrate any of these.
I forgot to mention 0 to 1 are the bounds of all 3.
Don't even try to integrate them. Can't you order the functions you are integrating on [0,1]?
I am trying to determine the order but I don't know how to do that without solving them.
Which is largest, sqrt(1+x^4), sqrt(1-x^4) or sqrt(1-x^8)?
+, but for the x to the 8th and 4th it depends on if 0<x<1 or if x is outside that range. If x is between 0-1, the order would be +, 8th power, 4th. If not in that range, +, 4th, and 8th.
I don't think these are integrable in terms of elementary functions.
But if you just want to sort them from lowest to highest, that shouldn't be too hard.
For example, compare the integrands of j and k:
\sqrt{1-x^4}
and
\sqrt{1+x^4}
Clearly the first one is \leq the second one for all x \in [0,1], and the inequality is strict for x \in (0, 1], so that implies j &lt; k.
Comparing the integrand for L shouldn't be too much harder - give it a try and let us know if you get stuck.
Didn't you say the range of integration is 0<=x<=1?
I did.
Dustinsfl said:
I did.
Hence, why are you worried about values outside that range?
http://www.quickmath.com/
  • · Replies 105 ·
  • · Replies 22 ·
