Projectile Kinetic Energy Calculation
  • Thread starter Thread starter oneplusone
    Projectile
The discussion centers on calculating the change in kinetic energy (KE) for two balls involved in a collision on a ramp. The first ball, released from rest, hits the second ball at the bottom of the ramp, and both fall off the table horizontally. The user applies conservation of energy to determine the final velocity of the first ball and uses kinematic equations to find the time of flight and horizontal distance traveled. The approach involves calculating the initial velocities of both masses after the impact and then determining the change in KE using the formula KE = 0.5m_1v_1^2 + 0.5m_2v_2^2. Clarification is sought on whether the velocities refer to just after the impact or at floor level, which is crucial for accurate KE calculation.
oneplusone
There's a ramp at the top of a table. You hold a ball of mass m1 at the top of the ramp, and release it starting at rest, so it hits ball with mass m2 which is initially at rest at the bottom of the ramp.
The ramp is set up, so the first ball hits the second, and they fall off the table and hit the floor. Also, when they fall off the ramp, it is parallel to the ground (so basically there's no y component of velocity).
You record the distances both balls travel, the height of the table, and height of the ramp.
Find the change in kinetic energy.
kinematics equations.
This is more of a lab, so KE is not conserved (lost in sound).
First I used conservation of energy to find the final velocity of the balling falling. that would just be v=sqrt(2gh)
The total kinetic energy would be then: 1/2 (m1)(2gh)
Next,
Using \Delta y = v_0t+\dfrac{1}{2}at^2
The initial velocity in the y direction is zero.
So we have: \Delta y = 0.5gt^2 \implies t = \sqrt{\dfrac{2y}{g}}.
Now from the x component, we have the same equation , but there is no acceleration so we have:
\Delta x = v_0t \implies v_0 = \dfrac{x}{t} = \dfrac{x}{\sqrt{\dfrac{2y}{g}}}.
Now plugging in the values collected for y and x, we can calculate the "initial velocities' of both masses (immediately after impact).
Then going back to KE = 0.5m_1v_1^2 +0.5m_2v_2^2
we can subtract these two and we are done.
Is this thinking correct? Or where could I have gone wrong?
Assuming zero air resistance and horizontal launch etc - that would be correct.
Both balls should hit at the same time, at different horizontal distances.
If v1 and v2 refer to the velocities just after impact, you have correctly found the change in KE from just before the collision to just after. Or are these the velocities at floor level?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
