How Does Uranus' Tilt Influence the Orbits of Its Moons?
  • Thread starter Thread starter elitenoobboy
    Moons Tilt Uranus
Uranus' unusual axial tilt is theorized to result from a collision with a protoplanet, which may have also influenced the orbits of its moons. Most of Uranus' moons are aligned with the equator, and some exhibit retrograde motion, suggesting a complex history of orbital evolution. The non-spherical nature of Uranus and gravitational interactions with the Sun and other celestial bodies contribute to the moons' current orbits. There is ongoing debate about whether the moons formed from debris before or after the impact that tilted Uranus, with some astronomers questioning the shared composition of the moons. Overall, the precise mechanisms behind the moons' rotations and their relationship to Uranus' tilt remain uncertain and require further investigation.
elitenoobboy
One of the leading theories that explains Uranus' tilt is that it was hit early in its lifetime by a protoplanet, which disrupted its rotation axis and caused its unusual tilt. How does this hypothesis explain Uranus' moons as well? Most of them are aligned to the equator, and some are also retrograde as well. If Uranus was hit by a protoplanet, how would that have changed the orbits of its moons to match its new rotation axis as well? Could the moons have been fragments of whatever protoplanet that hit it?
Astronomy news on Phys.org
I think that's the general presumption... But, it's not certain.
Planets are not spherical bodies, particularly so the rapidly-spinning gas giants. The non-spherical nature of the planets gravity fields coupled with perturbations from the Sun, nearby planets, and other moons causes the orbits of the inner moons to migrate toward being equatorial orbits.
If so, then is the presumption that they are from before or after the moon hit it? ie, formed from the debris of the protoplanet that broke up before impact, or formed from the debris that was knocked off the planet from the impact?
How long would this typically take? Millions of years, hundreds of millions, longer? Also, how much of an effect would the perturbations from the Sun and other planets and such have on equatorializing the moons? ie, is it mostly from the bulge of Uranus, or from the perturbations?
I know that many scientists believe that an Earth-sized planet collided with Uranus early on in its life, which they in turn believe is what knocked the planets onto its akward axis. As far is the moons go, there seems to be a definite lack of information about why they rotate the way that the do. Some astronomers think that the moons are peices of the planet that collided with Uranus. There are astronomers out there that believe that the axial tilt of Uranus and its moons is due to some sort of phenomina that we've yet to discover.
I guess what I'm saying is that we've yet to find a real answer.
Wouldn't that imply that they share the same composition? Miranda and Titania certainly have different internal compositions, and whatever composes the surface of Oberon, it's not whatever composes the surface of Miranda.
Yes, you're correct. At least in my mind. This is one of the reasons why I find it hard to accept this theory.
The main point of contention for me is that even if Uranus' moons were splintered off of some larger object post-collison, it still wouldn't explain their rotations. Yes, it's acceptable that a collision could knock Uranus on its side, but if the other object shattered, where in the laws of physics does it say that the peices of such an object would than follow the same, albeit strange, rotation? I'm just not convinced... Furthermore, I can't seem to find any information about the rotations of the moons anywhere. Not online (at least not from credible sources) and not in texts. If anyone has some solid information, I'd love to hear it.
Another point of interest worth mentioning, I think it was Voyager 2 that observed that Uranus had a very unique magnetic field; the tail of it seemed to be cork screwed. One can only wonder if maybe this was caused by the planet's rotation or maybe even had an influence on the planet's rotation...
I'm engaging purely in hypotheticals, though. Just my wandering mind.
Leonardo de N said:
Let me provide a totally different reason for the tilt. If Uranus had a bi-magnetic base it would rotate approx. 90 degrees from a planet such as Earth which has a ferro-ni core.
How exactly would a tilted magnetic core affect the entire rotation of the planet?
