Time at given speed in freefall
The discussion revolves around calculating the time it takes for a car to reach 90 km/h after rolling off a cliff. Participants emphasize the importance of converting units from km/h to m/s to ensure accuracy in calculations. The correct approach involves using the equation v(t) = v_0 + at, leading to a time of approximately 2.55 seconds when accounting for gravitational acceleration. Some participants discuss alternative equations and methods, highlighting the need to avoid assumptions about constant velocity during free fall. The conversation illustrates common pitfalls in physics problems, particularly regarding unit conversion and understanding acceleration.
KingNothing
Here is a problem from my book:
If a car rolls gently (initial velocity = 0) off a vertical cliff, how long does it take to reach 90km/h?
It seems easy, and I have been breezing through all teh other ones like it's my job, but for some reason this one gets me. I knwo it's possible, but I just don't know how. The answer is supposed to be 2.6 seconds, but I somehow always wind up dividing 90 by 9.8. Any help?
Are you familiar with the expression:
v(t) = v_0 + \frac{1}{2} a t^2?
Just solve it for t.
- Warren
Alright, thanks...but I still seem to get the wrong answer consistently. I do:
90=0.5(9.8)t^2
90=4.9t^2
18.37=t^2
t=4.29
what is going wrong?
Convert 90 km/hr into m/s first, so that your units will agree.
- Warren
Thanks, I don't know how I skipped that. That's what happened on the quiz, too. Did all of them perfectly, then on one forgot to convert.
Also, is it just me, or should I really end up with about 2.26 seconds?
I get 2.258769757 on my calculator using g = 9.8 m/s^2.
Does the problem explicitly say we can ignore air resistance?
Chroot: I must confess that during the several days I spent in calculus (and physics) class, I never saw an equation that said
"v(t) = v_0 + \frac{1}{2} a t^2"
I do recall seeing one that said "v(t)= v_0+ at" and one that said "d(t)= d_0+ v_0t+ \frac{1}{2}at^2".
Assuming no air resistance and that a= -9.8 m/s2, with v0= 0, v(t)= -9.8 t m/s. Since there are 1000m in a km and 60*60= 3600 sec in and hour, -90 km/hr= -90 *1000/3600= -25 m/s.
-25= -9.8 t so t= 25/9.8= 2.55 seconds.
Looks pretty easy to me (as long as you don't listen to Chroot!).
(C'mon, who is it that's using Chroot's good name?)
I'm sure it was just an oversight. :smile:.
GAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH!
*slinks into a corner and hides*
- Warren
Or you can use
v^2 = v0^2 + 2aΔx.
Solve for Δx and then time is just Δx/v.
Optimus, you can't do that because once you've solved for the distance its fallen, dividing by v means you are assuming that the velocity is constant, which it obviously isn't.
- Warren
I blindly assumed chroot's equation was correct.
Give me back the two minutes of my life I wasted!
Besides, x is not given.
Actually, under a constant acceleration, you can compute the time using the average velocity.
Given the final velocity and displacement, to solve for t:
t = \frac{2 d}{V_f} or
\frac{V_f}{2} = \frac{d}{t}
Vf/2 when Vi=0 and acceleration is constant gives the average velocity.
