- #106
DrGreg
- 1,959
The turn around occurs when Alice reaches (m), which is at 16:00 according to her own clock. This is something everybody agrees upon. Alice knows it because she is there and looks at her own clock when it happens. Bob does not know that it has happened immediately but has to wait until light has traveled from (m) to (a). When this has happened, Bob can see that Alice has turned round and he can see that her clock was showing 16:00 when it happened.Sam Woole said:I do not think your tables are honest. Your first table showed the turn around took place when the moving clock has accumulated 60 minutes, 60 vs 40 (40 was the illusion in the telescope. Actual number was 60 due to 20 minutes delay). Your second table showed the turn around took place when the moving clock has accumulated 90 minutes, 90 vs 60 (60 is the illusion in the telescope. Actual number is 80 due to 20 minutes delay.). This was the point I could not understand. I did not find any solution to it in your post.
If you accept that the Doppler factor of 2/3 applies to both Bob's view of Alice and Alice's view of Bob, then you have to accept that the red rows of both tables are correct.
...according to Alice.Sam Woole said:My understanding of your original tables was, it was a two hour return journey, one hour each way.
It doesn't. Bob sees the turn around when his clock shows 13:30, but the turn around has already taken place some time earlier. It takes time for light to travel from Alice at (m) to Bob at (a).Sam Woole said:I do not understand how could the turn around take place when one clock has accumulated 90 minutes.
Alice's journey appears to Bob to be 90 minutes because of the delay in light traveling from Alice to Bob. The 2/3 factor applies: a journey of 60 minutes by Alice's clock looks to Bob like a journey of 60 / (2/3) = 90 minutes. Alice's journey appears to Alice to be 60 minutes because she sees no delay on her own clock. The return trip journey is not symmetrical -- it is Alice who turns round, not Bob. The event of her turning round is experienced directly by Alice but can only be observed remotely, after a delay, by Bob.Sam Woole said:I did not challenge the truthfulness of the equal row, nor the definition of simultaneity. What I did challenge was your consistency. You changed rules of the game by prolonging the one way journey to 90 minutes which made the equal row disappear, and as a result the turn around took place 30 minutes later.
I answered that in my last post. Once clocks have been separated you cannot apply the time on one clock to events that occur at the position of the other clock.Sam Woole said:Although you changed the time on Alice clock to be 15:00 hours at start, but the equal row was still there in the first table above, 13:40 and 16:40, accumulation of 100 minutes on each clock, or 1:40 hours, meaning light is instantaneous. How could it be so?
Think of a clock like the trip-meter on a car. If you zero the trip-meters on two cars, and then the two cars follow each other along the same road, at the end both trip-meters show the same mileage. But if the two cars follow different routes, when they later meet, the mileage may be different.
For example suppose you and I meet in New York and zero the trip-meters on our cars. You drive directly to Los Angeles. I drive to New Orleans first, then I drive on to Los Angeles. When you and I meet again in Los Angeles, I have driven further than you. Our trip-meters show different numbers even though we are both in the same place.
Clocks behave the same way. If two clocks follow two different routes through space-time, they may show different accumulated times when they are brought back together again.
This is what I said in post #68:Sam Woole said:I had an inkling that people cannot make the time dilation idea stand unless they contradict themselves, such as the equal row. I believe it was all an illusion. You said so in the beginning; you knew it was.
The illusion would be if Alice believed that Bob's clock really was ticking at 2/3 the rate. It is still true that what she sees (after a delay) is Bob's clock's image which ticks at 2/3 the rate of the image of her own clock.DrGreg said:From Alice’s point of view, it looks as though Bob’s clock is ticking at 2/3 of the rate of her own clock. Of course, this is an illusion – it is nothing more or less than the Doppler effect, caused by the delay of the light signals.
