Does a proton age differently when accelerated at high speeds?
-=Red=-
Very quick question here that's bugging me.
I go to the LHC and send a proton around at 0.999999991c. After 5 seconds of that speed I stop it and take it out. Has the proton become younger or older, by x years, than when it was put in?
Thanks!
After doing a little thought experiment I conclude that the proton sent around the accelerator would indeed be younger...not by much mind you, but still, younger...am I correct?
-=Red=- said:
After doing a little thought experiment I conclude that the proton sent around the accelerator would indeed be younger...am I correct?
Yes!.. Wait.. No! Not younger than when it entered the accelerator! But younger than the 5 seconds it would have aged if you had not put it into the accelerator. For example if the proton was y years older when you put it in, then when you take out it will be younger than (y years + 5 seconds) old, but older than y years.
YES! Thats exactly what I was getting at! Thanks so much!
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
